[Geoserver-users] GeoServer Security
I am using GeoServer Version 2.2.4, and have been using it without any security on the data layers accessed using OpenLayers. I am now trying to add layer security to some of my layers. I have been researching this and it appears that I need to add authentication to the header of each request (or at least that is one option). I create the authorization string as follows:
var userpass = username + “:” + password;
I calculate the base64 encoding of the string as below:
var auth = make_basic_auth(userpass); //The make_basic_auth() function utilizes the Base64.js from Webtoolkit.
Then I add the following to the options in the HTTP request:
headers: {Authorization: auth}
In viewing the header of the request in Firebug, the authorization string is included in the request header. But, the layer is not being read because I get the pink tiles. I am using a ProxyHost.
If I am trying to accomplish the basic authorization in the wrong way, please let me know. Any suggestions that you may have are greatly appreciated.
Jerome Wendell
Did you try
http://osgeo-org.1560.x6.nabble.com/Load-GeoServer-WMS-secured-layers-with-OpenLayers-td3919938.html
The answer from Andreas should help.
Christian
On Wed, Aug 28, 2013 at 2:34 AM, Jerome A. Wendell <jawendell@anonymised.com> wrote:
Jerome Wendell
Learn the latest–Visual Studio 2012, SharePoint 2013, SQL 2012, more!
Discover the easy way to master current and previous Microsoft technologies
and advance your career. Get an incredible 1,500+ hours of step-by-step
tutorial videos with LearnDevNow. Subscribe today and save!
http://pubads.g.doubleclick.net/gampad/clk?id=58040911&iu=/4140/ostg.clktrk
Geoserver-users mailing list
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
Christian,
Thanks for your reply. I had not seen that specific post. I will give that a try.
I appreciate your help.
Jerome Wendell
From: Christian Mueller [mailto:christian.mueller@anonymised.com]
Sent: Wednesday, August 28, 2013 1:53 AM
To: jawendell@anonymised.com…5547…
Subject: Re: [Geoserver-users] GeoServer Security
Did you try
Christian
Jerome Wendell
Christian,
Thanks again for your reply. Using the information from Andreas in the post that you referenced below, I was able to access the secured layer.
Thanks again,
Jerome Wendell
Did you try
Christian
On Wed, Aug 28, 2013 at 2:34 AM, Jerome A. Wendell <jawendell@anonymised.com…> wrote:
Jerome Wendell
