[Geoserver-users] Geoserver SLD issue
Hey All
I have an architectural issue and not sure how to proceed, any suggestions
will be helpful.
I have a geoserver rending static layers for my web app client that uses
OpenLayers. Each layer has a table associated with it. I define user defined
styles for each layer for Line color, fill color in a different table based
on the user who logs in.
I am basically trying to implement dynamic styling for the geoserver layer.
Here are some options I have tried and some reasons they did not work
1. Added the UserStyle as part of SLD_BODY - unfortunately GET request
limits for IE messed this plan
2. Generate a UserStyle as text/xml in an action and set the SLD = action -
unfortunately it looks like the SLD parameter need a physical SLD file, so I
might have to publish an SLD file everytime user changes the style values
which might be something I dont want to consider right now.
3. Using POST - does not work out of the box since OpenLayers does not
support this out of the box.
So my question is is there any other alternative way of handling this issue?
Thanks & Regards
Ajay Ravichandran
View this message in context: http://www.nabble.com/Geoserver-SLD-issue-tp24118420p24118420.html
Hi Ajay,
ajayr wrote:
Hey All
will be helpful.
I could be wrong, but I thought that the remote SLD could be a dynamic script, as long as the appropriate content type headers are set in the response. Others will correct me if I am wrong. What happens when you try to use the script? Do you see any exceptions in the geoserver log? The remote URL also must be visible from the server, not from the client.
Thanks & Regards
Ajay Ravichandran
Justin Deoliveira
OpenGeo - http://opengeo.org
Hey Justin
Well I have a URL with an action within which the response header is set to
"text/xml" and I use PrintWriter to write the StyledLayerDescriptor string
to the response.
But for some reason I get a "SAXParseException: white spaces are required
between systemId and publicId ".
If I take the same XML string write it to an sld file placed on the server
and add the URL to the sld file to the GetMap request's SLD argument, it
works beautifully.
So you see, it works if the StyledLayerDescriptor tag is in an sld file and
the SLD parameter of the geoserver's Getmap request points to an sld file,
but doesnt work if I am writing the StyledLayerDescriptor contents directly
to the response
Any ideas??
Thanks
Ajay
Justin Deoliveira-6 wrote:
Hi Ajay,
ajayr wrote:
Hey All
suggestions
will be helpful.
defined
based
layer.
so I
issue?
Thanks & Regards
Ajay Ravichandran
Justin Deoliveira
Are you an open source citizen? Join us for the Open Source Bridge
conference!
Portland, OR, June 17-19. Two days of sessions, one day of unconference:
$250.
Need another reason to go? 24-hour hacker lounge. Register today!
http://ad.doubleclick.net/clk;215844324;13503038;v?http://opensourcebridge.org
Geoserver-users mailing list
View this message in context: http://www.nabble.com/Geoserver-SLD-issue-tp24118420p24150158.html
ajayr ha scritto:
Hey Justin
to the response.
It would seem the SLD you're generating has an error in the very first
lines of it (header). Can you attach a sample?
works beautifully.
Maybe storing on the file system changes the content encoding of the file? Not sure. Is your sld generator publicly available so that we can hit it directly?
to the response
Directly to the response... if you want to use dynamic styles your GetMap request should look something like:
...&sld=http://host/generator?param1=value1%26param2=value2
Where http://host/generator is your dynamic sld generator (a servlet, a php script).
Hey Andrea
I have attached the file : http://www.nabble.com/file/p24151304/demo.xml
demo.xml . This file has a one line string that is what I return from my
action ( i have just put it in a file for convenience).
[ I have also a formatted version , in case you want to look into it :
http://www.nabble.com/file/p24151304/formatted.xml formatted.xml .]
Unfortunately I do no have this functionality available public.
But the SLD parameter on my GetMap request is as follows
SLD=http://localhost:8080/WebPuff4.0.1/wms.do?REQUEST=GetStyle&TYPENAME=styleDynamicLayerStyle&namedLayer=webpuff:farm&bodyColor=#FF0000&borderColor=\#00FF00&borderWidth=1\.0&discriminatorColumn=label&discriminatorValue=Range24A&layerLabel=label
(it is in fact URL encoded, but i have removed the encoding in this post to
make it easier to understand)
The above URL returns a text/xml string that is contained in the demo.xml
file attached above.
Also here is the small section of Action code where I write it to my
response
PrintWriter out = response.getWriter();
response.setContentType("text/plain");
out.print(sb.toString());
(here sb is the Style string)
Please let me know if you need more information. also the error looks like
this
http://www.nabble.com/file/p24151304/error.jpg
Appreciate all the help
Andrea Aime-4 wrote:
ajayr ha scritto:
Hey Justin
to
string
to the response.
server
works beautifully.
hit it directly?
and
file,
directly
to the response
php script).
conference!
$250.
View this message in context: http://www.nabble.com/Geoserver-SLD-issue-tp24118420p24151304.html
