Hi List,
Doing some performance testing (WMS GetMap) on a GeoServer (2.7.2) with PostGreSQL (9.5.2) using JMeter, we’re getting some odd slowdowns. It seems that for a short while (up to a few minutes) GeoServer massively slows down in responding to requests; the “max” times shoot up from a few seconds to about 60-70 seconds! We’ve had this across several environments with PostGres, but the same tests on Oracle have never exhibited this.
The issue isn’t on the PostGres end - the slowest query there during the tests takes about 4 seconds, there’s no queuing and the resource usage on its (separate to GeoServer) box is negligible.
If I make the same request to GeoServer directly when not part of this testing, it only takes a second or two, so there’s nothing obviously wrong with the requests either. The problem is also proving difficult to replicate reliably.
The connections to PG are via Tomcat using a JNDI pool.
Has anyone encountered this sort of behaviour before or have any inkling as to the cause?
Jonathan
most likely cause is that you have saturated the postgis connection pool and are waiting for earlier requests to complete.
I can’t think of anything else obvious that might cause that problem.
Ian
On 12 May 2016 at 13:08, Jonathan Moules <jonathan-lists@anonymised.com> wrote:
Hi List,
Jonathan
Mobile security can be enabling, not merely restricting. Employees who
bring their own devices (BYOD) to work are irked by the imposition of MDM
restrictions. Mobile Device Manager Plus allows you to control only the
apps on BYO-devices by containerizing them, leaving personal data untouched!
https://ad.doubleclick.net/ddm/clk/304595813;131938128;j
Geoserver-users mailing list
Ian Turton
Hi Ian,
Thanks for the suggestion but we don’t think it’s that. On the PG box there were no logs indicating that the pool had run out, and on the GeoServer side I can’t seem to hit the pool limit when it’s as low as 20 but using 98 threads to test a single instance.
We’re thinking the behaviour we’re seeing seems more like garbage collection locking up an set of instances for a while (once its freed up, those instances were going better than the not-locked-up ones). Is GC a plausible mechanism?
Jonathan
---- On Thu, 12 May 2016 13:23:02 +0100 Ian Turton<ijturton@anonymised.com…> wrote ----
Ian
Hi List,
Jonathan
https://lists.sourceforge.net/lists/listinfo/geoserver-users–
Ian Turton
On Thu, May 12, 2016 at 3:44 PM, Jonathan Moules <
Hi Ian,
Thanks for the suggestion but we don't think it's that. On the PG box
GeoServer side I can't seem to hit the pool limit when it's as low as 20
but using 98 threads to test a single instance.We're thinking the behaviour we're seeing seems more like garbage
You can use VisualVM connected to the JVM to see if and when it's running
GC.
Do you have high CPU usage during the slowdonw?
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
