I am developing an application that prescind the Geoserver for the user.
I need add new DataStore, CoverageStore, Coverage, FeatureType, Styles without the utilization of GeoServer Admin.
I downloaded the source code of GeoServer, but I need for help.
Exists tutorial for help-me?
Best Regards,
Fernando Quadro
Hi Fernando,
IT sounds like what you need is hte REST configuration extension. With it you can add all these things with simple HTTP calls, without interacting with the admin UI.
http://docs.geoserver.org/1.7.x/user/extensions/rest/index.html
Hope that helps.
-Justin
Fernando Quadro wrote:
I am developing an application that prescind the Geoserver for the user. I need add new DataStore, CoverageStore, Coverage, FeatureType, Styles without the utilization of GeoServer Admin.
I downloaded the source code of GeoServer, but I need for help. Exists tutorial for help-me?
Best Regards,
Fernando Quadro
Crystal Reports - New Free Runtime and 30 Day Trial
Check out the new simplified licensing option that enables unlimited royalty-free distribution of the report engine for externally facing server and web deployment. http://p.sf.net/sfu/businessobjects
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Justin,
Thanks for the reply. But, to use cURL in java, I use the cURL library (http://sourceforge.net/projects/javacurl)?
Best Regards,
Fernando Quadro
Thu, 21 May 2009 10:13:27 -0700, Justin Deoliveira <jdeolive@anonymised.com> escreveu:
Hi Fernando,
Hope that helps.
-Justin
> Hi,
> Best Regards,
> Fernando Quadro
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
Justin Deoliveira
