[Geoserver-users] Geoserver SQL View that uses an existing fuction
I am attempting to create a Geoserver SQL View layer that uses an existing function in my Postgres/Postgis database.
Starting with the simplest case I have successfully created a layer using the following SQL statement on the Edit SQL View page:
SELECT geom FROM map.parcel WHERE pkid = %pkid%
Then I create a function in the database:
CREATE OR REPLACE FUNCTION map.gs_parcel (_pkid integer)
RETURNS TABLE (geom public.geometry) AS
$body$
BEGIN
RETURN QUERY
SELECT p.geom FROM map.parcel p WHERE pkid = _pkid;
END;
$body$
LANGUAGE ‘plpgsql’
VOLATILE
CALLED ON NULL INPUT
SECURITY INVOKER
COST 100 ROWS 1000;
And I try to create a SQL View using:
SELECT geom FROM map.gs_parcel(%pkid%)
But I get the error:
ERROR: function map.gs_parcel(integer) does not exist Hint: No function matches the given name and argument types. You might need to add explicit type casts. Position: 34
What am I doing wrong? I need to expand this simple example to take multiple parameters and add logic, which I can only do using pl/pgsql.
Hi Derek
did you give pkid a suitable default value?
On Tue, Sep 13, 2016 at 10:38 AM, Derek Watling <derek@anonymised.com> wrote:
$body$
BEGIN
RETURN QUERY
END;
$body$
LANGUAGE ‘plpgsql’
VOLATILE
SECURITY INVOKER
COST 100 ROWS 1000;
Geoserver-users mailing list
Geoserver-users@anonymised.comsourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
I have supplied a default value of 0.
I enter the "View Name" and "SQL statement" and click "Guess parameters from
SQL". When it brings up the list I enter the "Default value" and then click
"Refresh" under "Attributes". This is when I get the error.
<http://osgeo-org.1560.x6.nabble.com/file/n5285490/GeoserverSQLViewError.png&gt;
I am running 64bit versions of GeoServer 2.9.0 / Tomcat 8.5.4 / PostgreSQL
9.5.3 / PostGIS 2.2.2 on Windows 2012 R2.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-SQL-View-that-uses-an-existing-fuction-tp5285479p5285490.html
Sorry, I was suffering from cross-server confusion.
I created the Postgres function on my local development server and was tring
to access it from GeoServer running on our production server.
This part of the problem solved.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-SQL-View-that-uses-an-existing-fuction-tp5285479p5285494.html
