[Geoserver-users] GeoServer stop working after some times
Hi All,
I was using GeoServer that came with opengeo suite 4.7.
After sometimes, it stops working give only 502 Bad Gateway in the web server.
I’ve used GeoServer for long time and never been like this before.
When I look at the geoserver.log, it is attached as below.
I’m using opengeo suite 4.7 server package on Ubutu 14.04 LTS on a remote server.
How can I solve this problem?
Does anyone has experience like this before?
Any idea/hint to fix it is highly appreciated.
Many thanks & best regards
Mr. Khun San Aung
geoserver-error.log (9.64 KB)
Have a nice day!
Mr. Khun San Aung
Can you paste tomcat log?
View this message in context: http://osgeo-org.1560.x6.nabble.com/GeoServer-stop-working-after-some-times-tp5230993p5231992.html
Hai i am getting the same problem in geo server. it is shutting frequently
with the above same log. can u please help me out.
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoServer-User-f3786390.html
that log doens’t provide any information about why GeoServer was shutdown, it just says that GeoServer start up and then was shut down.
This usually means that something went wrong at the tomcat level (or whatever container you are using) and GeoServer was shut down.
If you are using Tomcat you should look for a directory in your Tomcat installation folders that contains something like this:
├── logs
│ ├── catalina.log
│ ├── catalina.out
│ ├── host-manager.log
The Catalina files should contain the information you need to understand what’s goign on.
Hope it helps,
Nuno Oliveira
Sent from: [http://osgeo-org.1560.x6.nabble.com/GeoServer-User-f3786390.html](http://osgeo-org.1560.x6.nabble.com/GeoServer-User-f3786390.html)
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
- Earning your support instead of buying it, but Ian Turton: [http://www.ianturton.com/talks/foss4g.html#/](http://www.ianturton.com/talks/foss4g.html#/)
- The GeoServer user list posting guidelines: [http://geoserver.org/comm/userlist-guidelines.html](http://geoserver.org/comm/userlist-guidelines.html)
If you want to request a feature or an improvement, also see this: [https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer](https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer)
[Geoserver-users@anonymised.comsts.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
Nuno Oliveira
GeoServer Professional Services from the
experts!
Visit http://goo.gl/it488V for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
55054  Massarosa (LU)
fax:      +39 0584 1660272
Con riferimento alla normativa sul trattamento dei dati
personali (Reg. UE 2016/679 - Regolamento generale sulla
protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo contenuto,
gli eventuali allegati, etc.) è un dato la cui conoscenza
è riservata al/i solo/i destinatario/i indicati dallo
scrivente. Se il messaggio Le è giunto per errore, è
tenuta/o a cancellarlo, ogni altra operazione è illecita.
Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to
which it is addressed and may contain information that
is privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European
Regulation 2016/679 “GDPR” - copying, dissemination or
use of this e-mail or the information herein by anyone
other than the intended recipient is prohibited. If you
have received this email by mistake, please notify
us immediately by telephone or e-mai
