[Geoserver-users] Geoserver stops responding and crashes
I tried this earlier here, hope this time someone will have an answer.
We are using Geoserver 2.6.0 on java 1.7.0_71 with Postgres (postgis) 9.2, running on a virtual server Windows Server 2008 R2.
Absolutely vanilla installation, no special confing either on Geoserver or Postgres side.
Geoserver keeps hanging and crashing, going through the log I found few different errors:
  1. java.lang.OutOfMemoryError: Java heap space
  2. org.geoserver.platform.ServiceException: Rendering process failed
  3. java.lang.RuntimeException: java.io.IOException
  4. org.geoserver.platform.ServiceException: This requested used more time than allowed and has been forcefully stopped. Max rendering time is 60.0s
and the more frequent:
  1. java.lang.RuntimeException: Unable to obtain connection: Cannot get a connection, pool error Timeout waiting for idle object
Attached are example backtraces for all errors.
Checked postgres and no errors there. I managed to check postgres while geoserver was struggling with error 5 and postgress was fine.
I’m not quite sure what is wrong. I reckon something around the java driver… but that’s a guess only.
We were to recommend Geoserver to our clients as a free OGC platform but won’t be able to do so until above issues present.
I would appreciate if anyone could point me out which way to start investigate or make changes.
Attila Peller
Augview | P O Box 125046, St Heliers, Auckland 1740, New Zealand
p: +64 9 575 5298 | m: +64 21 210 8420
cid:image001.png@anonymised.comNew Zealand Spatial AwardsAPSEA Winner Logo small
Winner of Innovation & Commercialisation and Supreme Awards at 2014 NZ Spatial Excellence Awards
Winner of Innovation & Commercialisation Award at 2014 Asia Pacific Spatial Excellence Awards
error 1 OutOfMemoryError.txt (17 KB)
error 2 ServiceException Rendering process failed.txt (13.4 KB)
error 3 IOException.txt (54.9 KB)
error 4 ServiceException 2.txt (9.89 KB)
error 5 Unable to obtain connection.txt (24.4 KB)
On Mon, Apr 27, 2015 at 11:56 AM, Attila Peller <attila@anonymised.com> wrote:
2.6.0 is six months old, wondering why you're not running 2.6.2 or 2.6.3?
Postgres side.
different errors:
Are you getting much traffic on that node? Or requesting large maps?
The vanilla installation at
http://sourceforge.net/projects/geoserver/files/GeoServer/2.6.0/geoserver-2.6.0.exe/download
is suitable for demo purposes, but not really recommended for production,
you should use a properly setup
Tomcat for production on a Windows platform.
Historically Windows has been the platform where people tested out things,
but then almost everybody
run production in a Tomcat on Linux.
Things are changing, as GeoServer starts breaking into Microsoft feuds, and
indeed we don't have a easy "click click click"
installer for a Windows production server, even if often people with light
needs just get manage with the current installer.
That said, given the other error messages you're getting, you are either
facing too much traffic, or might have
poorly setup styles/database indexes.
is 60.0s
This is also compatible with either very slow hardware, poorly setup styles
(e.g., trying to display everything at once at low zoom levels), or lack of
indexes.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
