[Geoserver-users] Geoserver stops responding
Hello list,
After working with geoserver a couple of hours its seems to stop
responding. I can't connect to the admin tool and any services (wms) its
serving stop working. I have to go in and restart the service to resolve
the issue. Any ideas what's going on?
Thanks in advance,
Mike
Michael Tafel| GIS Specialist| Denver Regional Council of Governments
Michael Tafel ha scritto:
Hello list,
After working with geoserver a couple of hours its seems to stop responding. I can’t connect to the admin tool and any services (wms) its serving stop working. I have to go in and restart the service to resolve the issue. Any ideas what’s going on?
Not unless you provide us with more information. Which GS version and Java version are you using? What kind of requests did GeoServer receive
during the two hours? What datastores are you using?
And more importantly, do you see any error in the log file? ($GEOSERVER_DATA_DIR/logs/geoserver.org)
If so, can you report the full stack traces you may find?
Andrea Aime
OpenGeo - http://opengeo.org
Yes of course, here is the info requested:
Geoserver version 1.6.4
Java version: 1.6.0
Datastore is PostGIS on PostgreSQL 8.3
Here is what the geoserver.log output was at the time it went down, no
errors were thrown only warnings:
2008-10-27 14:33:18,778 WARN [geoserver.filters] - Setting mimetype
after acquiring stream! was:text/html; charset=UTF-8; set to: text/html;
url was: http://arthur:8081/geoserver/demo.do
2008-10-27 14:33:19,809 INFO [geoserver.filters] - Compressing output
for mimetype: text/html; charset=UTF-8
2008-10-27 14:33:32,325 INFO [geoserver.filters] - Compressing output
2008-10-27 14:35:22,777 INFO [geoserver.filters] - Not compressing
output for mimetype: image/png
2008-10-27 14:35:22,980 INFO [geoserver.filters] - Not compressing
2008-10-27 14:35:23,246 INFO [geoserver.filters] - Not compressing
Here is the request log:
10.0.1.139 - - [27/10/2008:20:35:21 +0000] "GET
/geoserver/wms?LAYERS=DRCOG%3Augb&STYLES=&SRS=EPSG%3A4326&FORMAT=image%2
Fpng&TILED=true&TRANSPARENT=true&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMa
p&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&BBOX=-106.171875,39.100226
00175344,-105.46875,39.6437675734185&WIDTH=256&HEIGHT=256 HTTP/1.1" 200
707
p&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&BBOX=-104.765625,39.100226
00175344,-104.0625,39.6437675734185&WIDTH=256&HEIGHT=256 HTTP/1.1" 200
2710
10.0.1.139 - - [27/10/2008:20:35:22 +0000] "GET
p&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&BBOX=-104.0625,39.10022600
175344,-103.359375,39.6437675734185&WIDTH=256&HEIGHT=256 HTTP/1.1" 200
864
p&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&BBOX=-104.0625,39.64376757
34185,-103.359375,40.18307014852533&WIDTH=256&HEIGHT=256 HTTP/1.1" 200
662
p&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&BBOX=-105.46875,39.1002260
0175344,-104.765625,39.6437675734185&WIDTH=256&HEIGHT=256 HTTP/1.1" 200
10921
10.0.1.139 - - [27/10/2008:20:35:23 +0000] "GET
p&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&BBOX=-104.765625,39.643767
5734185,-104.0625,40.18307014852533&WIDTH=256&HEIGHT=256 HTTP/1.1" 200
3435
What happens with the admin tool is a "page not found error" comes up in
the browser, and the wms services being used in openlayers don't draw
and seem to wait for the server infinitely.
Thanks for the response.
-----Original Message-----
Sent: Tuesday, October 28, 2008 10:06 AM
To: Michael Tafel
Cc: geoserver-users@lists.sourceforge.net; Sara Eberhardt
Subject: Re: [Geoserver-users] Geoserver stops responding
Hello list,
its
resolve
Andrea Aime
Java version: 1.6.0
707 10.0.1.139 - - [27/10/2008:20:35:21 +0000] "GET
2710 10.0.1.139 - - [27/10/2008:20:35:22 +0000] "GET
864 10.0.1.139 - - [27/10/2008:20:35:22 +0000] "GET
662 10.0.1.139 - - [27/10/2008:20:35:21 +0000] "GET
10921 10.0.1.139 - - [27/10/2008:20:35:23 +0000] "GET
3435
Ugh, there is not a single error there. Are you sure GeoServer is still
up? On some linux distributions map rendering can
occasionally segfault, but in that case the whole web container
goes down so it becomes pretty evident cause the process dies immediately.
Andrea Aime
It's all running on Windows Server 2003 sp 2
To get it to work again I manually restarted the service. It works fine
now after the restart.
Michael Tafel| GIS Specialist| Denver Regional Council of Governments|
Sent: Tuesday, October 28, 2008 12:10 PM
To: Michael Tafel
Java version: 1.6.0
text/html;
text/html;
text/html;
text/html;
text/html;
text/html;
text/html;
text/html;
200
707
2710
864
662
200
10921
3435
in
immediately.
Andrea Aime
