On Wed, Apr 8, 2015 at 10:51 AM, Ben Crane <curtly.boon@anonymised.com> wrote:
Hey all,
I've run into a problem all of a sudden. When I try to look at a style I
get the following error:
org.apache.wicket.WicketRuntimeException: Can't instantiate page using
constructor public
org.geoserver.wms.web.data.StyleEditPage(org.apache.wicket.PageParameters)
and argument name = "[MyStyle]"
When I go to a Layer -> Publishing I get the following:
org.apache.wicket.WicketRuntimeException: Exception in rendering
component: [MarkupContainer [Component id = defaultStyle]]
I've made no changes to the server (other than restarting it) so not sure
how this has come about. I'm guessing it's about styles but not sure what
is wrong?
Has anyone had this issue before?
Does not ring a bell... could you share the full track traces with the same
error messages, they are found in the logs (which you can also access from
the UI).
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
