[Geoserver-users] GeoServer support for WKT geospatial data that is read from a database
Hi community,
I have geospatial data stored in a MemSQL database in the Well-Known Text (WKT) format. I would like to visualize it in GeoServer.
MemSQL supports the MySQL Wire Protocol and therefore I used the GeoServer MySQL Extension (http://docs.geoserver.org/latest/en/user/data/database/mysql.html) in order to create a data store.
When I create a GeoServer layer from a MemSQL table and preview it, it renders as an empty map.
It seems that GeoServer doesn’t have support for WKT when it is read from a database. But it supports WKT when it is read from a Java Properties file (http://docs.geoserver.org/latest/en/user/data/vector/properties.html)
Has anyone tried to get GeoServer to render and present WKT data from a database?
All the best,
Sari
Hi Daniel,
reading WKT from a normal database is not all that useful, since normally you cannot spatially index
a varchar column :slight_smile:
Is this what you’re using, geospatial memsql support?
http://docs.memsql.com/4.1/concepts/geospatial/
If so, I’d write a memsql datastore that can actually encode the right sql for bbox queries (it looks
memsql specific), in order to have support for spatial indexes. Or if you don’t know how to do that,
check out the commercial support page at geoserver.org to find someone that can do the coding
on your behalf.
See also: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
On Fri, Nov 27, 2015 at 1:10 PM, Daniel Tyler <danieltyler85@anonymised.com> wrote:
Hi community,
All the best,
Sari
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
