Does geoserver still support VPF format? I am using Geoserver 2.5. When I
clicked the http://geoserver.org/display/GEOS/Download link to download VPF
extension and got: HTTP 404 error. Does it mean Geoserver has dropped
support for VPF? If so, is there other way that allows me to use VPF with
Geoserver?
Geoserver?
“Accelerate Dev Cycles with Automated Cross-Browser Testing - For FREE
Instantly run your Selenium tests across 300+ browser/OS combos.
Get unparalleled scalability from the best Selenium testing platform available
Simple to use. Nothing to install. Get started now for free.” http://p.sf.net/sfu/SauceLabs
Thanks for your help. I got the link by following the instruction from the
User Manual. It looks like the link from the User Manual is wrong and it
needs to be updated.
Thanks for your help. Your link worked. However, I did not see vpf-plugin
on the list of extensions for 2.5 release. VPF plugin only shows up on
release 2.4.6. Does it mean support for VPF has been dropped from Geoserver
after 2.4.6 release? If VPF is dropped from future geoserver releases,
what is the work around that allows me to use it in geoserver? Can I use
2.4.6 VPF plugin with geoserver 2.5? What is the performance of geoserver
VPF plugin?
Geoserver
Yes, it has been dropped due to extended lack of a maintainer.
VPF plugin?
Not sure it will work, it may not. About the performance, no idea, I've
never used it
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Ing. Andrea Aime @geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
The code did not have a module maintainer (i.e. funded developer looking after it). As a result it had suffered bit-rot: tests had gradually been commented out (during the transition to GeoTools 10 feature model).
We have not thrown it out, as the format can be saved with a bit of elbow grease - but it will require money or love
Geoserver?
