Thanks to the hard work of James MacGill, the Geoserver SVN is back up!
We're being hosted by the fine folks at http://codehaus.org (thats also
where our WIKI and JIRA tracker is).
For those wanting read-only access to the archive, you can checkout
geoserver like this:
svn co svn://svn.codehaus.org/geoserver/scm/trunk/geoserver
To just view the archive online through your web-browser:
http://svn.codehaus.org/?root=geoserver
OR
https://svn.codehaus.org/geoserver/trunk/geoserver/
For those with commit access, you access the achive here:
NOTE: For those using subclipse, you may need to upgrade to a newer
version. If you get an "Server certificate verification failed: issuer
is not trusted" error, you need the newer version. See below.
James is trying to recover the old username/password for those with
commit rights. If he cannot do this we'll have to get new passwords.
More info later.
For more info, see:
http://docs.codehaus.org/display/GEOS/Source+Code
or
http://docs.codehaus.org/display/GEOS/GeoserverAndEclipse
dave
This mail sent through IMP: https://webmail.limegroup.com/
