[Geoserver-users] geoserver svn down?
Is it just me, or is svn down? I keep getting 'svn: Connection closed unexpectedly' when trying to svn update my geoserver (trunk) source tree. I also tried to do a fresh checkout, but got the same error. Geotools svn works OK, though.
Vincent.
hmm it seems to be working for me. Maybe it was a temporary problem on codehaus and it is back up.
Brent Owens
(The Open Planning Project)
Vincent.
opinions on IT & business topics through brief surveys - and earn cash
Geoserver-users mailing list
Hmm, still not working for me, so it might be a local problem with my network... Anywatys, thanks for the info.
Vincent.
Brent Owens
Vincent.
I still can't reach geoserver svn from here. Tried from different computers at different (physical) locations (all in the Netherlands though) through different providers, but no luck. Everytime getting the 'Connection closed unexpectedly' message. Maybe someone could investigate, of give me some hints on how to find the problem here?
Vincent.
Brent Owens
Vincent.
It works fine from here too... so, Codehaus is somewhere in the states afaik (?), Brent is in Canada and has no problems, I'm in Italy and it works fine from here too (tried from two different connections, two
different providers as well, and to make sure the second one was
a pure anonymous contact, no developer login information around).
I tested with
svn co https://svn.codehaus.org/geoserver/branches/1.4.x 1.4.x
So it seems to be some internet issue that's hitting Netherlands?
I tested with
Ha, that appears to be the reason. You are using the https:// url, I was using the svn:// url.
https://svn.codehaus.org/geoserver/trunk/ works for me (but I thought it would only work if you had commit access, that's what http://docs.codehaus.org/display/GEOSDOC/3+Source+Code seems to suggest).
svn://svn.codehaus.org/geoserver/trunk/ does *not* work however, which is the url that is suggested on the GEOS dev doc website.
Well, glad it works now, but maybe someone should test the svn:// url access, or correct the webpage?
Thanks for looking into this,
Vincent.
Geoserver-devel mailing list
connections, two different providers as well, and to make sure the
second one was a pure anonymous contact, no developer login
information around). I tested with svn co
suggest). svn://svn.codehaus.org/geoserver/trunk/ does *not* work
website. Well, glad it works now, but maybe someone should test the
Bonk! :slight_smile: (head falling on the table)
Sorry, I did not realize that could be the problem. Yeah, svn:// never
worked for me neither, but I did not use the guide so I did not notice
it was wrong...
Fixed it now. Thank you for reporting :slight_smile:
Andrea Aime
Glad you got it working. I will update the docs so there is less confusion.
Brent Owens
I tested with
Vincent.
