I am new to Geoserver. I got 50 WMS layer and 4 MSSQL database layer. After publishing these WMS and MSSQL layers using OL3, the map dashboard is taking too much time to fetch these layers.
I have tried to solve this through Tile Caching option but the result is same. Please suggest me any solution for this.
There are a few guides online about how to speed up performance - the usual approach is to 1) ensure your data has a spatial index (for when zoomed in) 2) use styling to filter content based on scale (when zoomed out) 3) look at data prep (simplification/reprojection) to optimize if you must
Subrata Chatterjee
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning reports. https://ad.doubleclick.net/ddm/clk/305295220;132659582;e
Subrata Chatterjee
