[Geoserver-users] Geoserver upgrade from 1.6.4 --> 1.7.0
Hello
After upgrading from Geoserver 1.6.4 à 1.7.0 I have had some issues.
n with rasters à some of them with a wrong palette (solved by coping raster.sld to the data_dir) and some other gone from the GetCapabilities.
n WFS stopped working, unable to Getcapabilities and to reach layers from any client.
What could have gone wrong?
Thank you in advance.
Pedro Soares Monteiro
Especialista em SIG
IROA, SA
Rua do Rosário, Quinta da SRAF
9600 – 549 Ribeira Grande
Pedro S. Monteiro ha scritto:
Hello
The raster issue has been talked about in the users list already.
The layers disappeared from the capabilities, it may be that the
datastore could not connect at geoserver startup and it was
disabled. Check if the datastore has the "enabled" checkbox
flagged.
Check in the goeserver logs, do you see any recent error? If so,
please attach the relevant portion of the logs in your next message.
Andrea Aime
OpenGeo - http://opengeo.org
The WFS GetCapabilities returns the follow XML
<ows:ExceptionReport version="1.0.0" xsi:schemaLocation="http://www.opengis.net/ows http://pm197930-ws:8080/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd&quot;&gt;
<ows:Exception exceptionCode="NoApplicableCode">
<ows:ExceptionText>
java.io.IOException
null
Translator error
This featureType is not enabled
</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
No error at log just the request
10.37.130.101 - - [17/Nov/2008:12:06:29 +0000] "GET /geoserver/ows?service=WFS&request=GetCapabilities HTTP/1.1" 200 299
Concerning the rasters gone from the GetCapabilities WMS, could it be a unsigned/unrecognized SRS.
Thank you for your help.
-----Original Message-----
Sent: segunda-feira, 17 de Novembro de 2008 10:44
To: Pedro S. Monteiro
Subject: Re: [Geoserver-users] Geoserver upgrade from 1.6.4 --> 1.7.0
Hello
GetCapabilities.
flagged.
Andrea Aime
Attached file with the output of the command line window, after WFS GetCapabilities.
Thank you
> Hello
> GetCapabilities.
flagged.
Andrea Aime
error.txt (6.38 KB)
