[Geoserver-users] [GeoServer-user] How? Native update of ImageMosaic Layer when new GeoTIFF appears in MOSAIC_DIR
Dear users,
I’ve established a data publication workflow where data providers publish image datasets circa 3 times per month. Each dataset gets published as separate GeoTIFF store and in addition I set up the ImageMosaic datastore providing the timeSeries for all datasets.
However, each time new dataset arrives to GeoServer (GeoTIFF store is created), the respective ImageMosaic DIR receives the new granule, but it does not create the database entry … thus it does not appear in timeseries layer with its TIME=YYYY-MM-DD.
I checked this tutorial: http://docs.geoserver.org/latest/en/user/tutorials/imagemosaic_timeseries/imagemosaic_timeseries.html#generated-property-file
And tried to change the config property value Caching=true since it didn’t work with Caching=false, however still the new dataset does not appear in the series.
Is it possible, or what am doing wrong?
Thank you,
Tomas
Tomas Kliment on about.me
Ing. Tomas Kliment, PhD.
about.me/klimeto
](http://about.me/klimeto)
Dear Tomas,
On Mon, Nov 16, 2015 at 4:48 PM, Tomas Kliment <tomas.kliment@anonymised.com> wrote:
Dear users,
Simply adding a file in the folder isn’t enough. You should also harvest that new dataset in ImageMosaic.
Please, take a look at this section of the Geoserver documentation:
http://docs.geoserver.org/latest/en/user/rest/examples/curl.html#uploading-and-modifying-a-image-mosaic
Specifically, the part where it says how to harvest a single file into the mosaic.
Please, keep it back to false.
Hope these suggestions can help.
Daniele
Thank you,
Tomas
about.me/klimeto
Presto, an open source distributed SQL query engine for big data, initially
developed by Facebook, enables you to easily query your data on Hadoop in a
more interactive manner. Teradata is also now providing full enterprise
support for Presto. Download a free open source copy now.
http://pubads.g.doubleclick.net/gampad/clk?id=250295911&iu=/4140
Geoserver-users mailing list
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
