[Geoserver-users] GeoServer username in SQL view
Hello List,
is there a way to get geoserver_user_name (something like ${GSUSER}) and to use in SQL view where clause:
select gid, geom, username from line where username = ${GSUSER}
Maybe where is a secret trick?
Sincerely,
Paulius
On Wed, Nov 5, 2014 at 2:47 PM, Paulius Litvinas <paulius@anonymised.com> wrote:
Hello List,
No, to my knowledge, there is no such support. It could be added with some
coding.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Andrea,
Thanks for the info.
I found interesting behaviuor: column user in geoserver SQL view is changed to current_user by geoserver and it returns username of postgis conection, instead of user column value.
Should it act like this?
Whats why I thougth about the trick with GSUSER J
Pagarbiai,
Paulius Litvinas
GIS konsultantas
line
map
S. Žukausko g. 17,
LT-08234 Vilnius, Lietuva
telephone
Tel. + 370 5 278 8456
Mob. +370 656 10 089
mail_and_earth
www.infoera.lt
info_era_autodesk
From: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com] On Behalf Of Andrea Aime
Sent: Wednesday, November 05, 2014 4:31 PM
To: Paulius Litvinas
Cc: GeoServer Mailing List List
Subject: Re: [Geoserver-users] GeoServer username in SQL view
Hello List,
No, to my knowledge, there is no such support. It could be added with some coding.
Ing. Andrea Aime
@geowolf
Technical Lead
