[Geoserver-users] Geoserver-users Digest, Vol 113, Issue 74
Hi Ben and Andrea,
I have tried the commands to find the "hs_err_pid log file", but I could not
find the file. Does there is something weird with my system?
Now I try to using openjdk, to test if the geoserver can run normal and
stable.
Thank you
Best Regards
-----Original Message-----
From: geoserver-users-request@lists.sourceforge.net
[mailto:geoserver-users-request@lists.sourceforge.net]
Sent: 19 Oktober 2015 2:19
Subject: Geoserver-users Digest, Vol 113, Issue 74
Send Geoserver-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
  geoserver-users-owner@lists.sourceforge.net
When replying, please edit your Subject line so it is more specific than
"Re: Contents of Geoserver-users digest..."
Today's Topics:
   1. Re: Geoserver Services Stopped Unexpectedly (Ben Caradoc-Davies)
   2. GeoServer w/ CAS Performance (Danny Cheng)
   3. Re: GeoServer w/ CAS Performance (Christian Mueller)
   4. Re: Geoserver 2.8.0 and Oracle - another try (GeoUser)
   5. GeoServer stop working after some times (KhunSanAung)
Message: 1
Date: Sun, 18 Oct 2015 10:12:21 +1300
Subject: Re: [Geoserver-users] Geoserver Services Stopped Unexpectedly
To: Muhammad Iqnaul Haq <iqnaulhaq@anonymised.com>
Cc: GeoServer Mailing List List
  <geoserver-users@lists.sourceforge.net>
Message-ID: <5622B9B5.40909@anonymised.com>
Content-Type: text/plain; charset=utf-8; format=flowed
On 18/10/15 04:08, Andrea Aime wrote:
On Sat, Oct 17, 2015 at 5:05 PM, Muhammad Iqnaul Haq
wrote:
Stopped means The geoserver process suddenly disappear without any
error logged on my server.
Oh ok, that means it's a hard JVM crash (could be a segmentation fault
or other problem).
You should find files named "hs_err_pid<numberHere>.log" in your file
system, they normally are in the directory where the java virtual
machine was launched, which can provide some information about it.
On Ubuntu you should be able to find these files using (as root):
updatedb
locate hs_err_pid
You will need to examine the times on the files to identify the one
corresponding to the crash. Please email this file to the list.
It is possible to have multiple Java implementation installed. It would be
most useful to confirm the JVM version both in GeoServer and at the command
line with:
ps -fwwC java
java -version
You can find all the installed java versions with:
update-java-alternatives -l
dpkg -l "openjdk*" "oracle-java*" | cat
Kind regards,
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt; New Zealand
Message: 2
Date: Sun, 18 Oct 2015 02:34:31 +0000
Subject: [Geoserver-users] GeoServer w/ CAS Performance
To: "geoserver-users@lists.sourceforge.net"
Message-ID:
  <162B07282B869D419AF8AC4DE77956DD39A358BA@anonymised.com>
Content-Type: text/plain; charset="us-ascii"
I currently have a system with CAS single sign on integrated. I noticed that
with CAS enabled my OGC requests are taking ~100ms longer to get a response.
Is this expected? I would expect that only the initial request would get a
hit, but for me all my requests are taking the hit.
Danny
Message: 3
Date: Sun, 18 Oct 2015 15:18:55 +0200
From: Christian Mueller <christian.mueller@anonymised.com>
Subject: Re: [Geoserver-users] GeoServer w/ CAS Performance
To: Danny Cheng <dcheng@anonymised.com>
Cc: "geoserver-users@lists.sourceforge.net"
Message-ID:
  <CAK2H3M1CCG7DXXNf0QnmJz9cN+m98NvaHdyHcBSypyv4RmEAmA@anonymised.com>
Content-Type: text/plain; charset="utf-8"
Hy Danny
Please check the log file of the CAS Server. There you can see the incoming
requests and check if each GeoServer request triggers a CAS request.
Christian
On Sun, Oct 18, 2015 at 4:34 AM, Danny Cheng <dcheng@anonymised.com>
wrote:
that with CAS enabled my OGC requests are taking ~100ms longer to get a
response. Is this expected? I would expect that only the initial request
would get a hit, but for me all my requests are taking the hit.
Danny
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
Message: 4
Date: Sun, 18 Oct 2015 11:32:21 -0700 (PDT)
Subject: Re: [Geoserver-users] Geoserver 2.8.0 and Oracle - another
  try
Message-ID: <1445193141797-5230985.post@anonymised.com>
Content-Type: text/plain; charset=us-ascii
Just in case...
If you run tomcat as a service, you can not specify Xmx, Xms.... in
startup/catalina.bat. You have to do it in the tomcat service administrator.
View this message in context:
http://osgeo-org.1560.x6.nabble.com/Geoserver-2-8-0-and-Oracle-another-try-t
p5230639p5230985.html
Message: 5
Date: Mon, 19 Oct 2015 01:48:20 +0630
Subject: [Geoserver-users] GeoServer stop working after some times
Message-ID:
  <CAAQr1jbVH_0bgO91XsCr5jRF2Eef2U+2uuHaQDiK3UdhcYCctw@anonymised.com>
Hi All,
I was using GeoServer that came with opengeo suite 4.7.
After sometimes, it stops working give only 502 Bad Gateway in the web
server.
I've used GeoServer for long time and never been like this before.
When I look at the geoserver.log, it is attached as below.
I'm using opengeo suite 4.7 server package on Ubutu 14.04 LTS on a remote
server.
How can I solve this problem?
Does anyone has experience like this before?
Any idea/hint to fix it is highly appreciated.
Many thanks & best regards
*Mr. Khun San Aung*
2015-10-18 20:26:27,326 INFO [config.XMLConfiguration] - Configuration file
validated fine.
2015-10-18 20:26:27,333 INFO [config.XMLConfiguration] - Initializing
GridSets from /var/lib/opengeo/geoserver/gwc
layers from /var/lib/opengeo/geoserver/gwc
2015-10-18 20:26:27,334 INFO [layer.TileLayerDispatcher] - Configuration
/var/lib/opengeo/geoserver/gwc contained no layers.
2015-10-18 20:26:27,377 INFO [diskquota.ConfigLoader] - DiskQuota
configuration not found:
/var/lib/opengeo/geoserver/gwc/geowebcache-diskquota.xml
2015-10-18 20:26:27,388 INFO [diskquota.ConfigLoader] - DiskQuota
2015-10-18 20:26:27,389 INFO [diskquota.DiskQuotaMonitor] - Setting up disk
quota periodic enforcement task
2015-10-18 20:26:27,389 INFO [diskquota.DiskQuotaMonitor] - 0 layers
configured with their own quotas.
2015-10-18 20:26:27,390 INFO [diskquota.DiskQuotaMonitor] - 28 layers
attached to global quota 500.0 MB
2015-10-18 20:26:27,400 INFO [diskquota.DiskQuotaMonitor] - Disk quota
periodic enforcement task set up every 10 SECONDS
2015-10-18 20:26:29,076 INFO [ows.OWSHandlerMapping] - Mapped URL path
[/gwc/service/**] onto handler 'dispatcher'
2015-10-18 20:26:29,098 INFO [geowebcache.GeoWebCacheDispatcher] - Invoked
setServletPrefix(gwc)
2015-10-18 20:26:29,133 INFO [georss.GeoRSSPoller] - Initializing GeoRSS
poller in a background job...
2015-10-18 20:26:29,135 INFO [georss.GeoRSSPoller] - No enabled GeoRSS
feeds found, poller will not run.
2015-10-18 20:26:29,232 INFO [rest.RESTDispatcher] - Created RESTDispatcher
with 14 paths
2015-10-18 20:26:29,270 INFO [wms.WMSService] - Will NOT recombine tiles
for non-tiling clients.
2015-10-18 20:26:29,271 INFO [wms.WMSService] - Will proxy requests to
backend that are not getmap or getcapabilities.
2015-10-18 20:26:30,619 INFO [ows.OWSHandlerMapping] - Mapped URL path
[/kml] onto handler 'dispatcher'
[/kml/*] onto handler 'dispatcher'
2015-10-18 20:26:30,620 INFO [ows.OWSHandlerMapping] - Mapped URL path
[/kml/icon/**/*] onto handler 'kmlIconService'
2015-10-18 20:26:30,707 INFO [ows.OWSHandlerMapping] - Mapped URL path
[/ows/**] onto handler 'dispatcher'
[/ows] onto handler 'dispatcher'
2015-10-18 20:26:30,722 INFO [org.geoserver] - GeoServer configuration lock
is enabled
2015-10-18 20:26:31,008 INFO [ows.OWSHandlerMapping] - Mapped URL path
[/wcs] onto handler 'dispatcher'
[/wcs/**] onto handler 'dispatcher'
2015-10-18 20:26:31,990 INFO [ows.OWSHandlerMapping] - Mapped URL path
[/wfs/*] onto handler 'dispatcher'
2015-10-18 20:26:31,991 INFO [ows.OWSHandlerMapping] - Mapped URL path
[/TestWfsPost] onto handler 'wfsTestServlet'
[/wfs] onto handler 'dispatcher'
2015-10-18 20:26:35,546 INFO [ows.OWSHandlerMapping] - Mapped URL path
[/wms/*] onto handler 'dispatcher'
[/wms] onto handler 'dispatcher'
2015-10-18 20:26:35,675 INFO [ows.OWSHandlerMapping] - Mapped URL path
[/animate] onto handler 'dispatcher'
2015-10-18 20:26:35,676 INFO [ows.OWSHandlerMapping] - Mapped URL path
[/animate/*] onto handler 'dispatcher'
2015-10-18 20:26:36,527 INFO [geoserver.wms] - Loaded font file
/var/lib/opengeo/geoserver/styles/DejaVuSans.ttf, loaded font 'DejaVu Sans'
in family 'DejaVu Sans'
2015-10-18 20:26:36,528 INFO [geoserver.wms] - Loaded font file
/var/lib/opengeo/geoserver/styles/DejaVuSerifCondensed-BoldItalic.ttf,
loaded font 'DejaVu Serif Condensed Bold Italic' in family 'DejaVu Serif
Condensed'
/var/lib/opengeo/geoserver/styles/DejaVuSerifCondensed.ttf, loaded font
'DejaVu Serif Condensed' in family 'DejaVu Serif Condensed'
2015-10-18 20:26:36,529 INFO [geoserver.wms] - Loaded font file
/var/lib/opengeo/geoserver/styles/DejaVuSansMono.ttf, loaded font 'DejaVu
Sans Mono' in family 'DejaVu Sans Mono'
/var/lib/opengeo/geoserver/styles/DejaVuSans-BoldOblique.ttf, loaded font
'DejaVu Sans Bold Oblique' in family 'DejaVu Sans'
/var/lib/opengeo/geoserver/styles/DejaVuSans-ExtraLight.ttf, loaded font
'DejaVu Sans ExtraLight' in family 'DejaVu Sans Light'
2015-10-18 20:26:36,530 INFO [geoserver.wms] - Loaded font file
/var/lib/opengeo/geoserver/styles/DejaVuSans-Oblique.ttf, loaded font
'DejaVu Sans Oblique' in family 'DejaVu Sans'
/var/lib/opengeo/geoserver/styles/DejaVuSansMono-Oblique.ttf, loaded font
'DejaVu Sans Mono Oblique' in family 'DejaVu Sans Mono'
/var/lib/opengeo/geoserver/styles/DejaVuSerif-Italic.ttf, loaded font
'DejaVu Serif Italic' in family 'DejaVu Serif'
2015-10-18 20:26:36,531 INFO [geoserver.wms] - Loaded font file
/var/lib/opengeo/geoserver/styles/DejaVuSansCondensed-Bold.ttf, loaded font
'DejaVu Sans Condensed Bold' in family 'DejaVu Sans Condensed'
/var/lib/opengeo/geoserver/styles/DejaVuSansCondensed-Oblique.ttf, loaded
font 'DejaVu Sans Condensed Oblique' in family 'DejaVu Sans Condensed'
2015-10-18 20:26:36,532 INFO [geoserver.wms] - Loaded font file
/var/lib/opengeo/geoserver/styles/DejaVuSerifCondensed-Italic.ttf, loaded
font 'DejaVu Serif Condensed Italic' in family 'DejaVu Serif Condensed'
/var/lib/opengeo/geoserver/styles/DejaVuSans-Bold.ttf, loaded font 'DejaVu
Sans Bold' in family 'DejaVu Sans'
/var/lib/opengeo/geoserver/styles/DejaVuSansCondensed.ttf, loaded font
'DejaVu Sans Condensed' in family 'DejaVu Sans Condensed'
2015-10-18 20:26:36,533 INFO [geoserver.wms] - Loaded font file
/var/lib/opengeo/geoserver/styles/DejaVuSerif.ttf, loaded font 'DejaVu
Serif' in family 'DejaVu Serif'
/var/lib/opengeo/geoserver/styles/DejaVuSansMono-BoldOblique.ttf, loaded
font 'DejaVu Sans Mono Bold Oblique' in family 'DejaVu Sans Mono'
2015-10-18 20:26:36,534 INFO [geoserver.wms] - Loaded font file
/var/lib/opengeo/geoserver/styles/DejaVuSerif-Bold.ttf, loaded font 'DejaVu
Serif Bold' in family 'DejaVu Serif'
/var/lib/opengeo/geoserver/styles/DejaVuSansMono-Bold.ttf, loaded font
'DejaVu Sans Mono Bold' in family 'DejaVu Sans Mono'
/var/lib/opengeo/geoserver/styles/DejaVuSerifCondensed-Bold.ttf, loaded
font 'DejaVu Serif Condensed Bold' in family 'DejaVu Serif Condensed'
2015-10-18 20:26:36,535 INFO [geoserver.wms] - Loaded font file
/var/lib/opengeo/geoserver/styles/DejaVuSansCondensed-BoldOblique.ttf,
loaded font 'DejaVu Sans Condensed Bold Oblique' in family 'DejaVu Sans
Condensed'
/var/lib/opengeo/geoserver/styles/DejaVuSerif-BoldItalic.ttf, loaded font
'DejaVu Serif Bold Italic' in family 'DejaVu Serif'
2015-10-18 20:26:36,543 INFO [geoserver.importer] - Enabling import store:
memory
2015-10-18 20:26:36,571 INFO [geoserver.security] - AuthenticationCache
Initialized with 1000 Max Entries, 300 seconds idle time, 600 seconds time
to live and 3 concurrency level
2015-10-18 20:26:36,572 INFO [geoserver.security] - AuthenticationCache
Eviction Task created to run every 600 seconds
2015-10-18 20:26:36,781 INFO [geoserver.security] - Start reloading
user/groups for service named default
2015-10-18 20:26:36,787 INFO [geoserver.security] - Reloading user/groups
successful for service named default
2015-10-18 20:26:37,540 INFO [georss.GeoRSSPoller] - destroy() invoked
2015-10-18 20:26:37,541 INFO [geowebcache.GeoWebCacheDispatcher] -
GeoWebCacheDispatcher.destroy() was invoked, shutting down.
2015-10-18 20:26:37,546 INFO [diskquota.DiskQuotaMonitor] - Disk quota
monitor shutting down...
2015-10-18 20:26:37,546 INFO [diskquota.DiskQuotaMonitor] - Shutting down
quota usage monitor...
2015-10-18 20:26:37,547 INFO [diskquota.QuotaUpdatesMonitor] - Shutting
down quota usage monitor...
2015-10-18 20:26:37,547 INFO [diskquota.DiskQuotaMonitor] - Shutting down
quota statistics gathering monitor...
2015-10-18 20:26:37,547 INFO [diskquota.QueuedQuotaUpdatesConsumer] -
Shutting down quota update background task due to InterruptedException
2015-10-18 20:26:37,547 INFO [diskquota.QueuedUsageStatsConsumer] -
Shutting down quota update background task due to interrupted exception
2015-10-18 20:26:37,548 INFO [seed.SeederThreadPoolExecutor] - Initiating
shut down for running and pending seed tasks...
2015-10-18 20:26:37,548 INFO [seed.SeederThreadPoolExecutor] - Seeder
thread pool executor shut down complete.
2015-10-18 20:26:37,548 INFO [storage.DefaultStorageBroker] - Destroying
StorageBroker
2015-10-18 20:26:37,551 WARN [support.DisposableBeanAdapter] - Invocation
of destroy method failed on bean with name 'geoServerLoader':
org.springframework.beans.factory.BeanCreationNotAllowedException: Error
creating bean with name 'geoWebCacheExtensions': Singleton bean creation
not allowed while the singletons of this factory are in destruction (Do not
request a bean from a BeanFactory in a destroy method implementation!)
Have a nice day!
*Mr. Khun San Aung*
* <http://geoportal.icimod.org/&gt;\*
Type: application/octet-stream
Desc: not available
End of Geoserver-users Digest, Vol 113, Issue 74
