[Geoserver-users] Geoserver-users Digest, Vol 113, Issue 90
Hello List
I have trouble to display overlaying rasters which contain topografic informations. The rasters are the german topografic map (DGK) which is represented by two layers: The base layer shows all roads and cities as value 0 rastercells, the relief layers shows all topolines as value 0 rastercells. The other cells have 1 as value. I translated them with gdal_translate to geotiff an set 1 as no_data value - which should get rid of those “no info cells”. In QGIS they show up properly and I can see both layers (1 value cells are transparent/ non existing). If used in GeoServer I am unable to see both layers, since the 1 value cells are rendered as white pixels. Something is wrong on the GeoServer side. Here are my settings:
SLD:
<?xml version="1.0" encoding="UTF-8"?><sld:StyledLayerDescriptor xmlns=“http://www.opengis.net/sld” xmlns:sld=“http://www.opengis.net/sld” xmlns:ogc=“http://www.opengis.net/ogc” xmlns:gml=“http://www.opengis.net/gml” version=“1.0.0”>
sld:NamedLayer
sld:Namec411930gs_ProjectRaster</sld:Name>
sld:UserStyle
sld:FeatureTypeStyle
sld:Rule
sld:RasterSymbolizer
sld:Geometry
ogc:PropertyNamegrid</ogc:PropertyName>
</sld:Geometry>
sld:ColorMap
<sld:ColorMapEntry color=“#000000” opacity=“1.0” quantity=“0.0”/>
<sld:ColorMapEntry color=“#444444” opacity=“0.0” quantity=“1.0”/>
</sld:ColorMap>
</sld:RasterSymbolizer>
</sld:Rule>
</sld:FeatureTypeStyle>
</sld:UserStyle>
</sld:NamedLayer>
</sld:StyledLayerDescriptor>
gdalinfo for one of the rasters:
Driver: GTiff/GeoTIFF
Files: N:/temp/Geonode/DataToImport/Hx/DGK_5/trans/c411930hf_ProjectRaster.tif
Size is 6299, 6299
Coordinate System is:
PROJCS[“ETRS_1989_UTM_Zone_N32”,
GEOGCS[“GCS_ETRS_1989”,
DATUM[“European_Terrestrial_Reference_System_1989”,
SPHEROID[“GRS 1980”,6378137,298.2572221010002,
AUTHORITY[“EPSG”,“7019”]],
AUTHORITY[“EPSG”,“6258”]],
PRIMEM[“Greenwich”,0],
UNIT[“degree”,0.0174532925199433]],
PROJECTION[“Transverse_Mercator”],
PARAMETER[“latitude_of_origin”,0],
PARAMETER[“central_meridian”,9],
PARAMETER[“scale_factor”,0.9996],
PARAMETER[“false_easting”,32500000],
PARAMETER[“false_northing”,0],
UNIT[“metre”,1,
AUTHORITY[“EPSG”,“9001”]]]
Origin = (32497927.420726549000000,5742142.373873201200000)
Pixel Size = (0.317379399999837,-0.317379399999984)
Metadata:
AREA_OR_POINT=Area
DataType=Thematic
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left (32497927.421, 5742142.374) ( 8d58’11.72"E, 51d49’48.37"N)
Lower Left (32497927.421, 5740143.201) ( 8d58’11.77"E, 51d48’43.66"N)
Upper Right (32499926.594, 5742142.374) ( 8d59’56.17"E, 51d49’48.38"N)
Lower Right (32499926.594, 5740143.201) ( 8d59’56.17"E, 51d48’43.67"N)
Center (32498927.007, 5741142.787) ( 8d59’ 3.96"E, 51d49’16.02"N)
Band 1 Block=6299x1 Type=Byte, ColorInterp=Palette
Min=0.000 Max=1.000
Minimum=0.000, Maximum=1.000, Mean=0.972, StdDev=0.164
NoData Value=1
Overviews: 3150x3150, 1575x1575, 788x788, 394x394, 197x197, 99x99
Metadata:
RepresentationType=THEMATIC
STATISTICS_COVARIANCES=2,68819748864689E-02
STATISTICS_MAXIMUM=1
STATISTICS_MEAN=0,97235370834899
STATISTICS_MINIMUM=0
STATISTICS_STDDEV=0,16395723493176
Color Table (RGB with 256 entries)
0: 0,0,0,255
1: 255,255,255,255
Hi Floarian,
GeoServer historically has had no support for “nodata” pixels.
In version 2.8.0 we have a first implementation of nodata support, but it’s not enabled by default
as we have seen some misbehaviors in it.
If you want to try it out, get GeoServer 2.8.0 and add the following system variable declarations to the “java”
call running the web container for GeoServer (e.g., Tomcat, Jetty):
-Dorg.geotools.coverage.jaiext.enabled=true
On Wed, Oct 21, 2015 at 4:59 PM, Florian Hoedt <gannebamm@anonymised.com> wrote:
Hello List
SLD:
sld:NamedLayer
sld:UserStyle
sld:Rule
sld:Geometry
</sld:Geometry>
sld:ColorMap
</sld:ColorMap>
</sld:Rule>
</sld:UserStyle>
</sld:NamedLayer>
Size is 6299, 6299
UNIT[“metre”,1,
Metadata:
AREA_OR_POINT=Area
DataType=Thematic
INTERLEAVE=BAND
Corner Coordinates:
Min=0.000 Max=1.000
NoData Value=1
Metadata:
0: 0,0,0,255
1: 255,255,255,255
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Andrea,
I can not update my GeoServer currently therefore the implementation you have mentioned is not possible for me.
There should be some way to define by SLD and layer config that one value should be transparent. Actually I had a setup which done exactly that, but I have no copy of the sld and layer config anymore.
On Thu, Oct 22, 2015 at 10:01 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Floarian,
Hello List
SLD:
sld:NamedLayer
sld:UserStyle
sld:Rule
sld:Geometry
</sld:Geometry>
sld:ColorMap
</sld:ColorMap>
</sld:Rule>
</sld:UserStyle>
</sld:NamedLayer>
Size is 6299, 6299
UNIT[“metre”,1,
Metadata:
AREA_OR_POINT=Area
DataType=Thematic
INTERLEAVE=BAND
Corner Coordinates:
Min=0.000 Max=1.000
NoData Value=1
Metadata:
0: 0,0,0,255
1: 255,255,255,255
Ing. Andrea Aime
@geowolf
Technical Lead
