Please can i have some help with my code here
Its not easy for me cause am not a programmer
I followed the instructions to set up a tiiling from geoserver with my data but the result is tiiling on hybrid map and i do not want this
I need the simple map (nor sattelite or hybrid )
the implementation is here http://www.mpe.gr/gmaps/arxaia.html
ps : i think that someone should rewrite the google tilling code cause google api has changed to v2, and some instructions to do simple things like that would be very helpful.
keep on the good work guys, geoserver was the solution for me. im not a programmer but im able to publish my data
On 5/25/07, geoserver-users-request@lists.sourceforge.net <geoserver-users-request@lists.sourceforge.net> wrote:
Send Geoserver-users mailing list submissions to
geoserver-users@lists.sourceforge.netTo subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body ‘help’ to
geoserver-users-request@lists.sourceforge.netYou can reach the person managing the list at
geoserver-users-owner@lists.sourceforge.netWhen replying, please edit your Subject line so it is more specific
than “Re: Contents of Geoserver-users digest…”Today’s Topics:
- Re: null value in log file (Andrea Aime)
- Re: null value in log file (Steve Marshall)
- output format SHAPe-ZIP corrupt (Pilon J. (Jos))
- Re: Problems including Views from Oracle Spatial (Rahkonen Jukka)
- Re: Problems including Views from Oracle Spatial (Luca Morandini)
Message: 1
Date: Thu, 24 May 2007 16:42:27 +0200
Subject: Re: [Geoserver-users] null value in log file
To: “jan w.” < wrobel.jan@…562…>
Cc: Steve Marshall <smarshall@…1212…>,
Message-ID: <4655A453.6050002@…1…>
Content-Type: text/plain; charset=ISO-8859-1; format=flowedjan w. ha scritto:
hi,
my requests come from on php script running on an IIS, seems to be a
problem with IIS?!
i could never reproduce the behaviour…Ah, one thing you could do, if the problem is relatively easy to
reproduce, is to run Geoserver interactively, instead of running
it as a service, and copy the stack traces you see from the console
window.Cheers
Message: 2
Date: Thu, 24 May 2007 11:13:31 -0700 (PDT)
Message-ID: <10789565.post@…381…>
Content-Type: text/plain; charset=us-asciimy requests come from on php script running on an IIS, seems to be a
problem with IIS?!
window.Andrea,
Sounds like a good sugestion. Unfortunately, the problem is actually rather
difficult to reproduce (the cause is unknown). Therefore, watching the
console is like looking for a needle in a haystack. I tried to startup
GeoServer in a console window, redirecting stdout and stderr to a log file
so I could search through loads of console information at my leisure. I did
the output redirection in the standard Linux way, i.e. by appending" >
log-file 2>&1" to the command. I believe this is also valid syntax for
Windows. However, when started this way, GeoServer seems to be unresponsive
after issuing this log message:14297 [FINE] org.geotools.data.jdbc.ConnectionPool - Getting available
connection.Any thoughts why this would happen? Are there any services associated with
Jetty I should restart to make changes take effect?Thanks for any insights,
Steve–
View this message in context: http://www.nabble.com/null-value-in-log-file-tf3680605.html#a10789565
Message: 3
Date: Thu, 24 May 2007 20:21:28 +0200
To: Steve Marshall <smarshall@…1212…>
Message-ID: <4655D7A8.8030307@…1…>
Content-Type: text/plain; charset=ISO-8859-1; format=flowedSteve Marshall ha scritto:
Jetty I should restart to make changes take effect?Not really, but I think I have a better suggestion.
Go in the Geoserver control panel, server section, and tell it to save
the logs to file, set a “CONFIG” logging level, submit, apply, and save.
To make sure the file is generated, kill and restart Geoserver, then
you should see a log directory in the Geoserver data dir with a
Geoserver.log file. The file growth will be jumpy, because we buffer
logs in memory and dump them every few kb to avoid slowing it down
too much, but once you have reproduced the issue, just stop
geoserver, and send me the log (by private mail, since the
mailing list won’t accept attachments).Cheers
Message: 4
Date: Fri, 25 May 2007 10:32:21 +0200
Subject: [Geoserver-users] output format SHAPe-ZIP corrupt
To: <geoserver-users@lists.sourceforge.net>
Message-ID:
< 25BB09C025B3A24F9F035EEDC27EA4DB03E5A43F@…1213…>
Content-Type: text/plain; charset=“us-ascii”Hi,
I have a few Oracle spatial (10.2) tables that I want to export as shape
files. But the zipped shapefile produced by Geoserver is corrupt
(terminated abnormally according to WinRar). Any ideas?Jos Pilon
Dit e-mail bericht is vertrouwelijk. Het is uitsluitend bestemd voor de geadresseerde.
Indien u niet de geadresseerde bent, verzoeken we u dringend ons direct te informeren en om dit bericht en eventuele bijlage(n) te verwijderen, zonder het te kopieren, door te zenden of op enige andere wijze te openbaren of te gebruiken. KLM Aerocarto BV, statutair gevestigd in Arnhem en geregistreerd in het Handelsregister onder nr. 09092085, is niet aansprakelijk voor welke schade dan ook als gevolg van communicatie per e-mail en verzending van documenten en gegevens. Tevens handelend onder de naam ARCADIS Ruimtelijke Informatie.This e-mail is confidential and may also be privileged. It is intended for use by the addressee only.
If you are not the intended addressee, we request that you notify us immediately and delete this e-mail, and any attachment(s), without copying, forwarding, disclosing or using it in any other way. KLM Aerocarto BV, with registered office at Arnhem, The Netherlands registered with the trade register under number 09092085, will not be liable for damage relating to the communication by e-mail of data or documents. Also active under the brand name ARCADIS Spatial Information.
An HTML attachment was scrubbed…
Message: 5
Date: Fri, 25 May 2007 13:58:37 +0300
Subject: Re: [Geoserver-users] Problems including Views from Oracle
Spatial
To: <geoserver-users@lists.sourceforge.net >
Message-ID:
<CC197224AC75CE4DB23F739B16891B86668969@…487…>
Content-Type: text/plain; charset=“iso-8859-1”Hi,
I am also having problems with Oracle spatial view and Geoserver 1.5.0. I am sure I have used views sometimes earlier, but I have no success in it now.
In order to make things as simple as possible I have created a view as a copy from a table that works as FeatureType (SELECT all fields without any WHEREs). USER_SDO_GEOM_METADATA is similar, despite TABLE_NAME, of course. The view works fine from SQL+. I can make FeatureType out of the view with administration utility and everything seems to be OK, including DescribeFeatureType, but all WFS queries are failing.I have here whole lot of text captured from Geoserver console. If there is somebody interested in it I can send it in another mail.
-Jukka Rahkonen-
L?hett?j?: geoserver-users-bounces@lists.sourceforge.net puolesta: Tom (JDi Solutions)
L?hetetty: ti 22.5.2007 23:07
Vastaanottaja: Andrea Aime
Kopio: geoserver-users@lists.sourceforge.net
Aihe: Re: [Geoserver-users] Problems including Views from Oracle SpatialThe view is user_sdo_geom_metadata. When you insert a record into it you must be logged in as the user who owns the view you’re adding and one of the fields (diminfo) in the user_sdo_geom_meta_data view requires an Oracle object constructor so it’s usually easier to copy one from a table that’s already registered (usually the one you’re basing the view on) for example:
INSERT INTO user_sdo_geom_metadata
(table_name, column_name, diminfo, srid)
SELECT ‘my_view’, ‘my_spatial_column’, diminfo, 4326
FROM user_sdo_geom_metadata
WHERE table_name = ‘my_base_table’;Hope that makes sense!
On 5/22/07, Andrea Aime <aaime@…1…> wrote:
Tim Englich ha scritto:
Hello,
I try to integrate a View from Oracle Spatial as an FeatureType to Geoserver
1.5.0 using the Webfrondend.
This failed.
When I configure the FeatureType manually by creating an Folder with info.xml
and schema.xml everything works fine.
Has anyone an Idea how I can tell the Webfrontend to do this?Well, usually you have to register view against some metadata table…
can’t remember the exact name, there should be some
USER_GEOMETRY_COLUMNS updatable view in MSYS_SDO (trying to remember,
haven’t checked so names may be quite a bit off the real ones).
Anyways, did you see any error in the Geoserver log when your attempt
failed?Cheers
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
Message: 6
Date: Fri, 25 May 2007 13:51:12 +0200
Spatial
Message-ID: <f36ijh$c1k$1@…101…>
Content-Type: text/plain; charset=ISO-8859-1; format=flowedRahkonen Jukka wrote:
success in it now. In order to make things as simple as possible I
but all WFS queries are failing.Have you already defined a Primary Key for such views ?
Luca Morandini
www.lucamorandini.it
Message: 7
Date: Fri, 25 May 2007 15:18:23 +0300
Spatial
To: <lmorandini@…309…>, < geoserver-users@lists.sourceforge.net>
Message-ID:
<CC197224AC75CE4DB23F739B16891B8666896E@…487…>
Content-Type: text/plain; charset=“iso-8859-1”L?hett?j?: geoserver-users-bounces@lists.sourceforge.net puolesta: Luca Morandini
L?hetetty: pe 25.5.2007 14:51Rahkonen Jukka wrote:
That was it. However, I faced a new problem next. Or actually it is an old problem that popped up again: Geoserver is creating invalid fids. Here is an example:
<gml:PERUSLOHKOT2 fid=“PERUSLOHKOT2.1602c310 :112c2aad0ac:3ffb”>Those colon characters make that fid is invalid, and my WFS client does not accept the data. My Geoserver version is 1.5.0 and that problem should be corrected in it. Obviously it is not the case in all situations.
-Jukka-
https://lists.sourceforge.net/lists/listinfo/geoserver-usersEnd of Geoserver-users Digest, Vol 12, Issue 33
Γεώργιος Τσολάκης - Περιβαλλοντολόγος
Γραφείο Περιβαλλοντικών Μελετών
Ζήνωνος 57. Περιστέρι. Αθήνα
tel: +30 210 5727615
fax: +30 210 5727995
mobile: + 30 6977 158693
email: gtsolakis@…84…
URL : www.mpe.gr
