On Tue, Jul 26, 2016 at 8:41 AM, Victor.Sinceac <Victor.Sinceac@anonymised.com>
wrote:
Did someone already find a solution to this?
Hi Victor,
I don't believe it's possible, it would require some development.
I assume one could just use the displacement element in the graphic,
assuming
the natural position is label center, and allowing to move the graphic
somewhere else
compared to it... but there is no code evaluating it now.
This would be a new feature request, see here on how to handle it:
https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
