[Geoserver-users] Geoserver-users Digest, Vol 28, Issue 13
Bruce,
Try using "sde://..." instead of "arcsde://..."
Not sure why that wiki says the wrong thing. See
http://svn.geotools.org/trunk/modules/plugin/arcsde/datastore/src/main/java/org/geotools/arcsde/gce/ArcSDERasterGridCoverage2DReader.java
method sdeURLToConnectionConfig()
One thing to note: your three-band image needs to be "photo-interpretable". Meaning that the three bands may need to be values that are exactly R, G and B (like a three-band photo). Otherwise you're out in "colormap-land" and you'll need to synthesize the ArcSDE work with the RasterSymbolizer support work that may be untested in conjunction with the ArcSDE code.
Good luck!
--saul
I've interpreted this connection statement in the help:
arcsde://user:pass@anonymised.com[GEOTOOLS::port]/[GEOTOOLS:dbname]#raster_table_name
[GEOTOOLS:;extra_param=extra_value]
...and used this connection string:
arcsde://viewer:pword@anonymised.com:5151#IMAGE.LANDSAT7_MOSAIC300
The current ArcSDE environment is ArcSDE 9.2 SP6 on Oracle 10.2.0.3. The
IMO:
Thanks for your help Saul and Gabriel,
sde, not arcsde in the connection string as per Saul’s email.
I have had a quick look through the code (big help!).
rtfm. I was missing the ‘/’ between the [GEOTOOLS::port]/[GEOTOOLS:dbname].
That solved another problem.
I still have another problem though. I suspect that the code may not handle a #raster_table_name
where the tablename also includes the fully qualified schema name as I’m trying to do. I may be wrong though.
I’ll spend some more time on this over the next few days.
Bruce Bannerman
geoserver-users-bounces@lists.sourceforge.net wrote on 04/09/2008 12:25:19 PM:
> Bruce,
> java
> Good luck!
> --saul
> This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
> Build the coolest Linux based applications with Moblin SDK & win great prizes
> Grand prize is a trip for two to an Open Source event anywhere in the world
> http://moblin-contest.org/redirect.php?banner_id=100&url=/
> Geoserver-users mailing list
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
Notice:
This email and any attachments may contain information that is personal, confidential,
legally privileged and/or copyright. No part of it should be reproduced, adapted or communicated without the prior written consent of the copyright owner.
It is the responsibility of the recipient to check for and remove viruses.
If you have received this email in error, please notify the sender by return email, delete it from your system and destroy any copies. You are not authorised to use, communicate or rely on the information contained in this email.
Please consider the environment before printing this email.
