[Geoserver-users] Geoserver-users Digest, Vol 33, Issue 45
We have come up with a fix, and possibly source of the problem.
We had the following layers.properties:
*.*.r=*
*.*.w=ROLE_ADMINISTRATOR
mode=MIXED
But we had disabled ACEGI - we use a different authentication scheme.
When we put *.*.w=*, the problem disappear.
Even though it was a quick fix, it shouldn't cause a data-corrupting crash.
Kind regards
Ugland IT Group AS
Thomas Jahnsen
Developer
Tel: + 47 67 59 28 23
E-mail: thja@anonymised.com
UGLAND IT GROUP AS, Strandveien 13, Pb. 58, 1324 Lysaker, org.nr. 971 058 773
Tlf: +47 67 59 28 10, fax: +47 67 59 28 11, email: firmapost@anonymised.com, internet: www.uglandit.com
Date: Fri, 13 Feb 2009 09:53:45 +0100
Subject: [Geoserver-users] Apply settings crashes in GeoServer 1.7.2
To: "'geoserver-users@lists.sourceforge.net'"
  <geoserver-users@lists.sourceforge.net>
Message-ID:
  <201931EA054F1746A294E8E5EA274A6071E251B533@anonymised.com>
Content-Type: text/plain; charset="us-ascii"
Hello
We have come up with a problem in our GeoServer installation, version
1.7.2. Whenever we hit 'Apply', the program crashes with a
RunTimeException. After this happens, all the WMS BaseLayers disappear
- if we see the Map Demo page, they are gone. If we hit 'Save', they
disappear from services.xml. If we hit 'Load', they reappar.
I suspect there are some corruption in the data, but have been unable
to determine what it is. The location of the exception and the result
suggests there is something wrong with the WMS base layers. I have
looked at the source code, but cannot find a cure.
GeoServer retrieves data fine, and we can do changes directly in the
XML in the data directory.
We run on Windows Server 2003 R2.
The stack trace:
java.lang.RuntimeException: Unknown resource type class $Proxy9
                at
org.geoserver.security.SecureCatalogImpl.checkAccess(SecureCatalogImpl.
java:323)
                at
org.geoserver.security.SecureCatalogImpl.getResourceByName(SecureCatalo
gImpl.java:239)
                at
org.vfny.geoserver.global.WMS.setBaseMapLayers(WMS.java:469)
                at org.vfny.geoserver.global.WMS.load(WMS.java:236)
                at
org.vfny.geoserver.action.UpdateGSAction.updateGeoserver(UpdateGSAction
.java:81)
                at
org.vfny.geoserver.action.UpdateGSAction.execute(UpdateGSAction.java:48
                at
org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
                at
org.apache.struts.action.RequestProcessor.processActionPerform(RequestP
rocessor.java:431)
                at
org.apache.struts.action.RequestProcessor.process(RequestProcessor.java
:236)
                at
org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
                at
org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
                at
javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
                at
javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
                at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(Applic
ationFilterChain.java:290)
                at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFil
terChain.java:206)
                at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetChara
cterEncodingFilter.java:108)
                at
ationFilterChain.java:235)
                at
terChain.java:206)
                at
org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
                at
                at
terChain.java:206)
                at
org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.ja
va:163)
                at
                at
terChain.java:206)
                at
org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
                at
                at
terChain.java:206)
                at
com.uitg.filters.AuthLogFilter.doFilter(AuthLogFilter.java:107)
                at
                at
terChain.java:206)
                at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperVal
ve.java:233)
                at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextVal
ve.java:191)
                at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.jav
a:128)
                at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.jav
a:102)
                at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve
.java:109)
                at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:
286)
                at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:8
45)
                at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process
(Http11Protocol.java:583)
                at
org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
                at java.lang.Thread.run(Unknown Source)
I hope some of you can help us with this problem.
Hi Thomas,
I am having a little trouble reproducing the error. I added the same to my layers.properties file and tried adding a new layer group, applied with no issue.
You say you disabled ACEGI? How did you do so?
-Justin
*.*.r=*
mode=MIXED
Kind regards
Ugland IT Group AS
Thomas Jahnsen
Developer
Message-ID:
Hello
The stack trace:
                at
java:323)
                at
gImpl.java:239)
                at
                at
.java:81)
                at
                at
                at
rocessor.java:431)
                at
:236)
                at
                at
                at
                at
                at
                at
terChain.java:206)
                at
                at
                at
terChain.java:206)
                at
                at
                at
terChain.java:206)
                at
va:163)
                at
                at
terChain.java:206)
                at
                at
                at
terChain.java:206)
                at
                at
                at
terChain.java:206)
                at
ve.java:233)
                at
ve.java:191)
                at
a:128)
                at
a:102)
                at
.java:109)
                at
286)
                at
45)
                at
                at
Open Source Business Conference (OSBC), March 24-25, 2009, San Francisco, CA
-OSBC tackles the biggest issue in open source: Open Sourcing the Enterprise
-Strategies to boost innovation and cut costs with open source participation
-Receive a $600 discount off the registration fee with the source code: SFAD
http://p.sf.net/sfu/XcvMzF8H
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Hi
ACEGI is disabled by removing/commenting out the ACEGI filter.
  <filter>
    <filter-name>Acegi Filter Chain Proxy</filter-name>
    <filter-class>org.acegisecurity.util.FilterToBeanProxy</filter-class>
    <init-param>
      <param-name>targetClass</param-name>
      <param-value>org.acegisecurity.util.FilterChainProxy</param-value>
    </init-param>
  </filter>
  <filter-mapping>
    <url-pattern>/Config</url-pattern>
  </filter-mapping>
Nothing more magic than that. The web.xml-file also says you can remove it if you use your own security system.
I hope this helps your attempts to reproduce the issue.
Kind regards
Ugland IT Group AS
Thomas Jahnsen
Developer
-----Opprinnelig melding-----
Fra: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Sendt: 13 February 2009 16:23
Til: Thomas Jahnsen
Kopi: 'geoserver-users@lists.sourceforge.net'
Emne: Re: [Geoserver-users] Geoserver-users Digest, Vol 33, Issue 45
Hi Thomas,
with no issue.
-Justin
> *.*.r=*
> mode=MIXED
crash.
> Kind regards
> Ugland IT Group AS
> Thomas Jahnsen
> Developer
058 773
>> From: Thomas Jahnsen <thja@anonymised.com>
>> Message-ID:
>> Hello
version
disappear
unable
result
>> The stack trace:
>> at
>> java:323)
>> at
>> gImpl.java:239)
>> at
>> at
>> .java:81)
>> at
>> at
>> at
>> rocessor.java:431)
>> at
>> :236)
>> at
>> at
>> at
>> at
>> at
>> at
>> terChain.java:206)
>> at
>> at
>> at
>> terChain.java:206)
>> at
>> at
>> at
>> terChain.java:206)
>> at
>> va:163)
>> at
>> at
>> terChain.java:206)
>> at
>> at
>> at
>> terChain.java:206)
>> at
>> at
>> at
>> terChain.java:206)
>> at
>> ve.java:233)
>> at
>> ve.java:191)
>> at
>> a:128)
>> at
>> a:102)
>> at
>> .java:109)
>> at
>> 286)
>> at
>> 45)
>> at
>> at
Francisco, CA
Enterprise
participation
code: SFAD
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
Justin Deoliveira
For reference, the jira ticket for this issue is:
http://jira.codehaus.org/browse/GEOS-2632
I was able to reproduce and it should be fixed now. Thanks for the bug report Thomas.
-Justin
*.*.r=*
mode=MIXED
Kind regards
Ugland IT Group AS
Thomas Jahnsen
Developer
Message-ID:
Hello
The stack trace:
                at
java:323)
                at
gImpl.java:239)
                at
                at
.java:81)
                at
                at
                at
rocessor.java:431)
                at
:236)
                at
                at
                at
                at
                at
                at
terChain.java:206)
                at
                at
                at
terChain.java:206)
                at
                at
                at
terChain.java:206)
                at
va:163)
                at
                at
terChain.java:206)
                at
                at
                at
terChain.java:206)
                at
                at
                at
terChain.java:206)
                at
ve.java:233)
                at
ve.java:191)
                at
a:128)
                at
a:102)
                at
.java:109)
                at
286)
                at
45)
                at
                at
Justin Deoliveira
