[Geoserver-users] Geoserver-users Digest, Vol 7, Issue 39
hello to all
Ive installed an application of geoserver. Geoserver tiles over google map . The results are the demostation of Natura 2000 (the European conservation network of nature ) in Greece !!
Link here http://www.mpe.gr/index.php?option=com_wrapper&Itemid=73
My problem is that my data (shapefile) is not getting where it is supposed to be.
My original data are in Greek coordinates (GGRS87 - GREEK GRID)
Is there a reason why is this happening? And any workaround to solve this?
George Tsolakis - Enviromentalist
On 12/29/06, geoserver-users-request@lists.sourceforge.net <geoserver-users-request@lists.sourceforge.net> wrote:
Send Geoserver-users mailing list submissions to
geoserver-users@lists.sourceforge.net
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body ‘help’ to
You can reach the person managing the list at
geoserver-users-owner@lists.sourceforge.net
When replying, please edit your Subject line so it is more specific
than “Re: Contents of Geoserver-users digest…”
Today’s Topics:
  1. postgis and wms (parmarp@…822…)
  2. Re: postgis and wms (Andrea Aime)
  3. Re: Point layer displays as two overlapping points (Brent Owens)
  4. Re: Point layer displays as two overlapping points (Chris Holmes)
  5. Re: Issue installing GeoServer 1.5.0-beta1 (windows
    executable) (Brent Owens)
  6. Re: Point layer displays as two overlapping points
    (david@…825… )
Message: 1
Date: Thu, 28 Dec 2006 20:35:56 -0800
Subject: [Geoserver-users] postgis and wms
Message-ID: < 45949B2C.5000504@…822…>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Hello everyone. Can somebody direct me to a site that shows how to setup
geoserver to draw maps using different tables in postgis ? I have tiger
census data imported into postgis and
have been using qgis to view it but i’d like to use WMS to generate a
map. I’ve been able
to add the tables as a featuretype into geoserver but i don’t know how
to generate a map using those tables.
Message: 2
Date: Fri, 29 Dec 2006 09:39:22 +0100
Subject: Re: [Geoserver-users] postgis and wms
To: “parmarp@…822…” < parmarp@…822…>
Message-ID: < 4594D43A.90001@…1…>
map. I’ve been able
Well, you can have a look at the quickstart guides on the geoserver
home page, for example, here:
http://docs.codehaus.org/display/GEOSDOC/SLD+Intro+Tutorial
and the tutorials here:
http://docs.codehaus.org/display/GEOSDOC/2+Tutorials
Also, have a look at the SLD and WMS specs on the OpenGeospatial site.
Hope this helps
Andrea Aime
Message: 3
Date: Fri, 29 Dec 2006 09:12:48 -0800
Subject: Re: [Geoserver-users] Point layer displays as two overlapping
points
To: david@…825…
Message-ID: < 45954C90.604@…84…>
Hi David,
It could be that you have two of the same in your SLD that will
cause the point to appear twice. If not that, then it might be there
there is another networklink pointing to the same layer lying around.
Brent Owens
(The Open Planning Project)
david@…825… wrote:
Hi all and happy holidays!
Another user question: I"m trying to serve a point layer via geoserver up
to Google Earth. For some reason, everything displays properly, but each
point is displayed twice (with two overlapping points, two labels, etc).
They are the same feature but are duplicate. Anyone else experience this
and know of a possible fix?
David
Join SourceForge.net’s Techsay panel and you’ll get the chance to share your
opinions on IT & business topics through brief surveys - and earn cash
Message: 4
Date: Fri, 29 Dec 2006 12:16:01 -0500
points
To: Brent Owens <brentowens@…84…>
Message-ID: <45954D51.6020301@…1…>
Content-Type: text/plain; charset=“iso-8859-1”
Hrm, I feel like we’ve had this problem before and we weren’t able to
replicate?
David, could you send us your SLD file so we can see if we can replicate
the problem?
Brent Owens wrote:
Hi David,
Brent Owens
David
!DSPAM:1003,45954d6b301271429667743!
Chris Holmes
http://topp.openplans.org
A non-text attachment was scrubbed…
Type: text/x-vcard
Desc: not available
Url : http://sourceforge.net/mailarchive/forum.php?forum=geoserver-users/attachments/20061229/be51d56b/attachment.vcf
Message: 5
Date: Fri, 29 Dec 2006 09:22:03 -0800
Subject: Re: [Geoserver-users] Issue installing GeoServer 1.5.0-beta1
(windows executable)
To: Tyler Erickson < tyler.erickson@…739…>
Message-ID: <45954EBB.1000108@…84… >
Hi Tyler,
Sorry for the late reply. Yes JAI and imageio area a bit of a pain. We
have included them in 1.4 and we need to work out something for 1.5.
There is a little JAI howto on the geotools site that I reference often
(http://docs.codehaus.org/display/GEOT/2.2+Dependencies)
We do need to move it over to the geoserver site and make it a little
easier to understand.
Brent Owens
Tyler Erickson wrote:
I am attempting to install GeoServer 1.5.0_beta1 from the windows installer.
After starting GeoServer from the Windows Start menu, I am unable to
successfully bring up geoserver in the browser.
I have attached a copy of the INFO and ERROR messages I receive in the
command prompt window.
The GeoServer_1.5.0_beta1 download page contains the notice… “You will
need JAI and ImageIO installed in your JRE in order to run this version of
GeoServer.” I’m not sure if this what the notice was referring to but I
downloaded and executed http://www.nabble.com/file/5054/JettyErrors.txt
JettyErrors.txt the JRE install
(http://download.java.net/media/jai-imageio/builds/release/1.1/jai_imageio-1_1-lib-windows-i586-jre.exe )
for the JavaTM Advanced Imaging Image I/O Tools Binary Builds
(https://jai-imageio.dev.java.net/binary-builds.html#Stable_builds ). It
might be a good idea to add a bit of text on how to install JAI and ImageIO
to the download page.
OS: Windows XP
java: jdk1.5.0_09
Message: 6
Date: Fri, 29 Dec 2006 10:49:56 -0800 (PST)
points
To: “Chris Holmes” <cholmes@…1…>
Cc: Brent Owens <brentowens@…84…>,
Message-ID: <2713.192.168.0.1.1167418196.squirrel@…825… >
Well, I’m using the point SLD file that came with the geoserver
distribution. I’ll include it again. Also of note, when displaying point
layers from the geoserver demo files, it looks fine. However, when using
my own data, I get double points. I’m using Arcview 9.1 to create the
shapefiles in case that has anything to do with it.
replicate?
the problem?
Brent Owens wrote:
Hi David,
Brent Owens
up
each
etc).
this
David
your
your
Chris Holmes
Type: application/octet-stream
Desc: not available
Url : http://sourceforge.net/mailarchive/forum.php?forum=geoserver-users/attachments/20061229/87450153/attachment.obj
End of Geoserver-users Digest, Vol 7, Issue 39
Γεώργιος Τσολάκης - Περιβαλλοντολόγος
Γραφείο Περιβαλλοντικών Μελετών
Ζήνωνος 57. Περιστέρι. Αθήνα
tel: +30 210 5727615
fax: +30 210 5727995
mobile: + 30 6977 158693
email: tsoler@…832…
URL : www.mpe.gr
George Tsolakis ha scritto:
hello to all
Have you specified the proper SRS in your feature type configuration?
I cannot think of anything else at the moment...
Andrea Aime
