Hi
I am from Bangalore, India. I am relatively new to Geoserver. I want o know, how can I develop my own customized Tools
Kind Regards,
Subodh Murari Patrikar
GIS Software Engineer
T: +91 80 4245 5555/23192209 (Ext - 514)
F:+91 80 4245 5556/23192210
E: subodh.p@anonymised.com
www.prdcinfotech.com
-----Original Message-----
From: geoserver-users-request@lists.sourceforge.net [mailto:geoserver-users-request@lists.sourceforge.net]
Sent: Thursday, December 27, 2012 17:03
Subject: Geoserver-users Digest, Vol 79, Issue 80
Send Geoserver-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
geoserver-users-owner@lists.sourceforge.net
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Geoserver-users digest..."
Today's Topics:
1. Re: Oracle Doesn't work (Andrea Aime)
2. Re: Oracle Doesn't work (Jonathan Moules)
Message: 1
Date: Thu, 27 Dec 2012 12:17:01 +0100
Subject: Re: [Geoserver-users] Oracle Doesn't work
To: Jonathan Moules <jonathanmoules@anonymised.com>
Message-ID:
<CA+nxMTt1Vz4UdQ9b5hroD9sEh9w64BzNYTy=tudozOcMuUdP1g@anonymised.com>
Content-Type: text/plain; charset="iso-8859-1"
On Thu, Dec 27, 2012 at 12:13 PM, Jonathan Moules <
jonathanmoules@anonymised.com> wrote:
Hi Andrea,
I hadn't set a schema. I guess this means I'll need to add a new layer for
each schema, even though its the same user reading it.
This does resolve the reading issue, however the MBR issue (
http://jira.codehaus.org/browse/GEOS-5517) is still evident even after
specifying a schema (note: there are only about 50,000 features in this
particular dataset).
Eh, I've never seen that error despite having worked with GeoServer and
Oracle several times, so I can only make some guess...
maybe your table in Oracle does not have a spatial index?
That is required for any spatial operation to work, which I guess including
computing the BBOX
If you switch the logging level to "GeoTools developer logging" the log
will become quite verbose, but it will
also include the SQL staments that GeoServer is sending to the database.
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Message: 2
Date: Thu, 27 Dec 2012 11:32:25 +0000
From: Jonathan Moules <jonathanmoules@anonymised.com>
To: Andrea Aime <andrea.aime@anonymised.com>
Message-ID:
<CAA-xNcX+qbZ=MiaWOxoS7QvS4C5GAoWKCiMOCUvfzev-zS7EgA@anonymised.com>
Definitely have a Spatial Index. I'd know it if I didn't. (but have
just double checked - its there).
This issue seems to be a little more nuanced than I previously thought.
Now when I click "Compute from data" Geoserver web interface doesn't appear
to respond at all. Not even the error. I get a little flower-loading icon
in the top right and that's it. After a minute or two the new bounding
co-ordinates are loaded, but for all intents and purposes it actually
appears that GeoServer has crashed during that period.
The console is still showing the permissions error, but also that the query
worked:
27 Dec 11:20:15 DEBUG [org.geotools.jdbc] - CREATE CONNECTION
27 Dec 11:20:15 WARN [org.geotools.jdbc] - Failed to use
SDO_TUNE.EXTENT_OF, falling back on envelope aggregation
java.sql.SQLException: ORA-00942: table or view does not exist
ORA-06512: at "MDSYS.SDO_TUNE", line 817
at
oracle.jdbc.driver.DatabaseError.throwSqlException(DatabaseError.java:112)
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:331)
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:288)
at oracle.jdbc.driver.T4C8Oall.receive(T4C8Oall.java:743)
at oracle.jdbc.driver.T4CStatement.doOall8(T4CStatement.java:207)
at
oracle.jdbc.driver.T4CStatement.executeForRows(T4CStatement.java:946)
at
oracle.jdbc.driver.OracleStatement.executeMaybeDescribe(OracleStatement.java:1060)
at
oracle.jdbc.driver.T4CStatement.executeMaybeDescribe(T4CStatement.java:830)
at
oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1132)
at
oracle.jdbc.driver.OracleStatement.executeQuery(OracleStatement.java:1272)
at
org.apache.commons.dbcp.DelegatingStatement.executeQuery(DelegatingStatement.java:208)
at
at
at
org.geotools.data.oracle.OracleDialect.getOptimizedBounds(OracleDialect.java:732)
at
org.geotools.jdbc.JDBCDataStore.getBounds(JDBCDataStore.java:1128)
at
org.geotools.jdbc.JDBCFeatureSource.getBoundsInternal(JDBCFeatureSource.java:501)
at
org.geotools.data.store.ContentFeatureSource.getBounds(ContentFeatureSource.java:426)
at
org.geotools.data.store.ContentFeatureSource.getBounds(ContentFeatureSource.java:363)
at
org.vfny.geoserver.global.GeoServerFeatureSource.getBounds(GeoServerFeatureSource.java:591)
at
org.geoserver.catalog.CatalogBuilder.getNativeBounds(CatalogBuilder.java:555)
at
org.geoserver.catalog.CatalogBuilder.getNativeBounds(CatalogBuilder.java:537)
at
org.geoserver.web.data.resource.BasicResourceConfig$1.onSubmit(BasicResourceConfig.java:115)
at
org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1.onSubmit(AjaxSubmitLink.java:68)
at
org.apache.wicket.ajax.form.AjaxFormSubmitBehavior.onEvent(AjaxFormSubmitBehavior.java:143)
at
org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:177)
at
org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:300)
at
org.apache.wicket.request.target.component.listener.BehaviorRequestTarget.processEvents(BehaviorRequestTarget.java:119)
at
org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:92)
at
org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1250)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436)
at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
at
org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484)
at
org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:160)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at
org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:159)
at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at
org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
at
org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at
org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23)
at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
at
org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
at
at
org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at
at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at
at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
at
org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at
at
org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at
at
at
at
org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
at
at
at
org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:146)
at
at
at
at
at
org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at
at
at
at
org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at
org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:97)
at
org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at
org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at
at
org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71)
at
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at
at
org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
at
at
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at
org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at
org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at
org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at
org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at
org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
at
org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at
org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at
org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at
org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:842)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:648)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at
org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
at
org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
27 Dec 11:20:15 DEBUG [org.geotools.jdbc] - SELECT
SDO_AGGR_MBR(SDO_GEOMETRY) FROM OSMM.OS_MM2_CONWY_TOPOGRAPHIC_AREA
27 Dec 11:21:38 DEBUG [org.geotools.jdbc] - CLOSE CONNECTION
I ran the same query in Oracle SQL Developer and it took 2 minutes! That's
a very long time to get an MBR for just 50,000 features. I dread to think
what'll happen when I point it at my ~15million feature table!
I think GeoServer should use the MDSYS.USER_SDO_GEOM_METADATA entry by
default - that's what its there for after all.
Jonathan
jonathanmoules@anonymised.com> wrote:Hi Andrea,
for each schema, even though its the same user reading it.
particular dataset).Eh, I've never seen that error despite having worked with GeoServer and
including computing the BBOXIf you switch the logging level to "GeoTools developer logging" the log
also include the SQL staments that GeoServer is sending to the database.Cheers
Andrea--
information.Ing. Andrea Aime
@geowolf
Technical LeadGeoSolutions S.A.S.
mob: +39 339 8844549http://www.geo-solutions.it
http://twitter.com/geosolutions_it-------------------------------------------------------
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Master Visual Studio, SharePoint, SQL, ASP.NET, C# 2012, HTML5, CSS,
MVC, Windows 8 Apps, JavaScript and much more. Keep your skills current
with LearnDevNow - 3,200 step-by-step video tutorials by Microsoft
MVPs and experts. ON SALE this month only -- learn more at:
http://p.sf.net/sfu/learnmore_122712
End of Geoserver-users Digest, Vol 79, Issue 80
Please consider the environment before printing this email. Do it only if it is absolutely necessary.
DISCLAIMER:
The contents of this email including attachment(s), if any, are intended for the exclusive use of the addressee(s) and
may contain proprietary, confidential or privileged information. If you have received this mail in error, please notify the
sender immediately and destroy all copies of this message and any attachment(s).Computer viruses or other malware
can be transmitted by email. Therefore, please check this email and any attachment(s) for the presence of viruses, malware,
etc. The PRDC accepts no liability whatsoever for any damage - whether direct or consequential - caused by any virus, malware,
etc. transmitted by this email.
DISCLAIMER:
