Hi Craig,
Hi All,
We are getting the exception below when downloading a large wfs response
in csv or gml format using gzip compression. Were are using geoserver
2.1.1 in production but this also happens in 2.3.3.
Have you tried forcing the database fetch size? I think you have to add it manually to datastore.xml for the featuretype your having problems with, like this:
<dataStore>
<connectionParameters>
<entry key="fetch size">200</entry>
HTH
Geoff
An HTML attachment was scrubbed...------------------------------
Message: 2
Date: Tue, 9 Jul 2013 10:53:13 +0545
Subject: [Geoserver-users] LayerSwitcher() not working
Message-ID:
<CAPrctb0L+bRCL+n4yzsKRpWRP9i7Suy==Ue7buHYHTpkaukJKA@anonymised.com>
Content-Type: text/plain; charset="iso-8859-1"Hi,
I'm using 5 layers and passing random values to VIEWPARAMS to select the
wanted area. I added a layer switcher(mentioned in red at the bottom of
the
script) to show/hide layers. but switch layer component doesn't appear on
openlayers map viewer. Please be kind to respond. need help.Regards.
<script src="wms_files/OpenLayers.js" type="text/javascript"></script>
<script defer="defer" type="text/javascript">
var legs = "<%= geoParam %>";
var layer_one_legs = "<%= geoParamLayerOne %>";
var layer_two_legs = "<%= geoParamLayerTwo %>";
var layer_three_legs = "<%= geoParamLayerThree %>";
var layer_four_legs = "<%= geoParamLayerFour %>";
var layer_four_five = "<%= geoParamLayerFive %>";var map;
var base;var layer_one;
var layer_two;
var layer_three;
var layer_four;
var layer_five;/* pink tile avoidance */
OpenLayers.IMAGE_RELOAD_ATTEMPTS = 5;
/* make OL compute scale according to WMS spec */
OpenLayers.DOTS_PER_INCH = 25.4 / 0.28;function init() {
format = 'image/png';
var bounds = new OpenLayers.Bounds(
97057.023,
174768.406,
118472.391,
192859.141);
var options = {
controls : ,
maxExtent : bounds,
maxResolution : 83.65378125000001,
projection : "EPSG:2020",
units : 'm'
map = new OpenLayers.Map('map', options);/* setup base layer */
base = new OpenLayers.Layer.WMS(
"Base",
"http://localhost:8080/geoserver/wms",
LAYERS : 'rda2',
transparent: "true",
singleTile: true,
format : format
buffer : 0,
isBaseLayer : true,
displayInLayerSwitcher:false
});/* setup layer_one */
layer_one = new OpenLayers.Layer.WMS(
"Layer 01",
VIEWPARAMS: layer_one_legs,
LAYERS : 'RDA2_VIEW_LAYER_ONE',
singleTile: true,
format : format
buffer : 0,
isBaseLayer : false,
displayInLayerSwitcher:true
});/* setup layer_two */
layer_two = new OpenLayers.Layer.WMS(
"Layer 02",
VIEWPARAMS: layer_two_legs,
LAYERS : 'RDA2_VIEW_LAYER_TWO',
singleTile: true,
format : format
buffer : 0,
});/* setup layer_three */
layer_three = new OpenLayers.Layer.WMS(
"Layer 03",
VIEWPARAMS: layer_three_legs,
LAYERS : 'RDA2_VIEW_LAYER_THREE',
singleTile: true,
format : format
buffer : 0,
});/* setup layer_four */
layer_four = new OpenLayers.Layer.WMS(
"Layer 04",
VIEWPARAMS: layer_four_legs,
LAYERS : 'RDA2_VIEW_LAYER_FOUR',
singleTile: true,
format : format
buffer : 0,
});/* setup layer_five */
layer_five = new OpenLayers.Layer.WMS(
"Layer 05",
VIEWPARAMS: layer_four_five,
LAYERS : 'RDA2_VIEW_LAYER_FIVE',
singleTile: true,
format : format
buffer : 0,
});/* map.addLayers([untiled, tiled ]); */
map.addLayers([base, layer_five, layer_four, layer_three, layer_two,
layer_one]);/* build up all controls */
map.addControl(new OpenLayers.Control.PanZoomBar(
position : new OpenLayers.Pixel(2,15)
map.addControl(new OpenLayers.Control.Navigation());
map.addControl(new OpenLayers.Control.LayerSwitcher());
map.zoomToExtent(bounds);
}</script>
Me on Web
http://dushan888.wordpress.com
http://www.linkedin.com/pub/dushan-basnayake/18/9a7/8b9
http://www.twitter.com/Dushi
Message: 3
Date: Tue, 9 Jul 2013 09:02:20 +0200
From: Daniele Romagnoli <daniele.romagnoli@anonymised.com>
Subject: Re: [Geoserver-users] Problems when running geoserver with
gdal extension
To: markusin <markus.innerebner@anonymised.com>
Cc: "geoserver-users@lists.sourceforge.net"
<geoserver-users@lists.sourceforge.net>
Message-ID:
<CAJaHrDw9U=nni=krMJSy9hrWegJbAGcrMwd_3Uu9Z=Y7fBgF1w@anonymised.com>
Content-Type: text/plain; charset="iso-8859-1"Hi Markus,
I guess you forgot to paste the error message.Cheers,
Daniele==
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.Ing. Daniele Romagnoli
Senior Software EngineerGeoSolutions S.A.S.
Via Poggio alle Viti 1187
fax: +39 0584 1660272http://www.geo-solutions.it
http://twitter.com/geosolutions_it-------------------------------------------------------
On Tue, Jul 9, 2013 at 12:11 AM, markusin
<markus.innerebner@anonymised.com>wrote:> Ciao Daniele,
> I did now all the steps from the tutorial and I was able to build =
> successfully everything. But now I got an error:
> when testing it:
> Do you think this error is related to my glibc version?=20
> I see in my installation:=20
> glibc-devel-2.12-1.7.el6_0.5.x86_64
> glib2-2.22.5-5.el6.x86_64
> I guess I have to upload this version on my redhat machine.
> Markus
> View this message in context:
> http://osgeo-org.1560.x6.nabble.com/Problems-when-running-geoserver-
with-gdal-extension-tp5062627p5064842.html
> Sent from the GeoServer - User mailing list archive at Nabble.com.
> This SF.net email is sponsored by Windows:
> Build for Windows Store.
> http://p.sf.net/sfu/windows-dev2dev
> Geoserver-users mailing list
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
See everything from the browser to the database with AppDynamics
Get end-to-end visibility with application monitoring from AppDynamics
Isolate bottlenecks and diagnose root cause in seconds.
Start your free trial of AppDynamics Pro today!
http://pubads.g.doubleclick.net/gampad/clk?id=48808831&iu=/4140/ostg.clktr
k------------------------------
https://lists.sourceforge.net/lists/listinfo/geoserver-usersEnd of Geoserver-users Digest, Vol 86, Issue 26
