[Geoserver-users] GeoServer User's Map
Hi
We have created a new GeoServer user’s map. The address is http://sigma.openplans.org/users/.
Please feel free to add yourself to the map. If you have any comments or questions, please contact me at iwillig at openplans.org
Thanks.
-Ivan
Fine,
but. I can’t open it in IE, not in IE6 nor IE7, only in Firefox. How come?
mika
Ivan Willig kirjoitti:
Indeed, can’t consult it either…
On Thu, Feb 28, 2008 at 4:05 PM, Lehtonen, Mika <mika@anonymised.com> wrote:
Fine,
mika
Hi
Thanks.
-Ivan
Defy all challenges. Microsoft(R) Visual Studio 2008.
[http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/](http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/)
Geoserver-users mailing list
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
I have geoserver (1.6.0) running successfully on my laptop. The database backend is PostGIS. I an running a virtual desktop (VMWare) and I installed PostGIS and geoserver. I backed up my database and restored it on the virtual desktop. However, when I go into geoserver and edit the feature type, I click the button to generate the extent and it correctly generates the extent but it places the lon extent as the lat extent and visa-versa. I've never seen this before but it is a bit troubling to me. Any thought or ideas? I looked at the data in the data base and it looks correct.
Thanks in advance, David
David R Robison
Open Roads Consulting, Inc.
708 S. Battlefield Blvd., Chesapeake, VA 23322
phone: (757) 546-3401
e-mail: drrobison@anonymised.com
web: http://openroadsconsulting.com
blog: http://therobe.blogspot.com
book: http://www.xulonpress.com/book_detail.php?id=2579
I found my problem. I was using an old version of web.xml that was missing the following lines.
   <!-- logging initializer, should be first thing to execute -->
  <listener>
    <listener-class>org.geoserver.GeoserverInitStartupListener</listener-class>
  </listener>
David
David R Robison
Hi David,
Yeah, this does not initializing of the geotools referencing system to tell it force coordinates to be long/lat or x/y axis ordering.
One thing to keep in mind, is that in GeoServer 1.6 support for wfs 1.1 has been added. In wfs 1.1, the default crs (4326) actually is forced to be in lat/long or y/x, which is different from teh wfs 1.0.
The upshot is that if you do a wfs 1.0 request, then do the same wfs 1.1 request you will see the coordinate values swapped. Just something to keep in mind.
-Justin
  <listener>
  </listener>
David
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
I’m trying it out on Firefox, and I keep getting the following dialog when I zoom in…
The page at http://sigma.openplans.org says:
Unhandled request return Not Found
and when I click the History link I get…
Request of type ‘Vespucci.Request.HistoryFeedRequest’ failed with error code 404. Map may not work properly.
  • Tyler
Ivan Willig wrote:
Tyler A. Erickson, Ph.D.
Research Scientist
Michigan Tech Research Institute
3600 Green Court, Suite 100
Ann Arbor, MI 48105
[tyler.erickson@anonymised.com](mailto:tyler.erickson@anonymised.com)
[www.mtri.org](http://www.mtri.org)
[www.michiganview.org](http://www.michiganview.org)
Yours truly pointed the new geoserver instance to the wrong data directory before going home on Friday, it's fixed now.
-Arne
Tyler Erickson wrote:
I'm trying it out on Firefox, and I keep getting the following dialog when I zoom in...
and when I click the History link I get...
Request of type 'Vespucci.Request.HistoryFeedRequest' failed with error code 404. Map may not work properly.
- Tyler
Ivan Willig wrote:
Hi
We have created a new GeoServer user's map. The address is http://sigma.openplans.org/users/. <http://sigma.openplans.org/users/&gt;
Please feel free to add yourself to the map. If you have any comments or questions, please contact me at iwillig at openplans.org <http://openplans.org/&gt;
Thanks.
-Ivan
Research Scientist
Ann Arbor, MI 48105
www.mtri.org
  !DSPAM:4038,47cb5e5d214461849620573!
