Am 15.12.2013 11:35, schrieb Arne Kepp:
The issue is probably that you're not encoding the parameters in
your request,
You're a prince, Arne! That did the trick!
localhost:8080/geoserver/wfs?request=getfeature&outputformat=csv&service=wfs&typename=tanzania%3ATan_regions&cql_filter=%28tanzania:REGION
like %27Tanga%27%29
Works perfectly as expected.
so you run into problems as soon as you try to use ":" or "(".
Strange enough,that the result was returned OK when I appended
&layers=tanzania:Tan_regions The CSV came back OK, regardless of the
delimiter between workspace and layer name was *not* escaped. Maybe
that helped to obscure the real problem for me....
Further the geoserver website recommends some examples:
http://docs.geoserver.org/stable/en/user/services/wfs/vendor.html
these I copied and as you see, they are *not* escaped....
To be frank: the documentation is fair at best....
http://www.php.net/manual/en/function.curl-escape.php
Is not available in PHP 5.4 as we use it in Debian 7... Announced for
5.5. So I will have to do it by hand...
If you have problems like this, you should set up a small
PHP-script that just echoes what the server receives, and then run
requests against that to spot differences in encoding etc.
I take this as a hint, that URLs sent to geoserver should *always* be
build with escaped special-chars....
Lesson learned and
Apologies for asking something, that may be obvious around here
thanks a lot..
HZN
-Arne
On 15/12/13 02:45 , Hartmut Noack wrote:
Hello,
I am about to scream.
using this url directly in the browser:
localhost:8080/geoserver/wfs?request=getfeature&outputformat=csv&service=wfs&typename=Tan_regions&cql_filter=(tanzania:REGION
like 'Tanga')
yields exactly what I am out for. But, alas... passing it as an
CURLOPT_URL to curl in PHP gives nothing. No error, no warning
and a ZERO-result.
The difference may have something to do with the CQL-Filter.
changing the url to:
makes curl return the csv as expected.
Anyway, filtering is requested and I really *would like* to
understand, why the first works in the Browser but not with curl
and the second one (without the filter) does work when sent with
curl.
Do I need to say, that in both cases the code for curl is exactly
the same?
curl_setopt($ch, CURLOPT_HEADER, 0); curl_setopt($ch,
CURLOPT_URL, $url); curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
curl_setopt($ch, CURLOPT_FORBID_REUSE, 1); //Collect result.
$result = curl_exec($ch); curl_close ($ch);
Please: if any body has a link to some documentation where I can
read about that issue, any hint to what is going on here would be
most appreciated....
best regards
HZN
Rapidly troubleshoot problems before they affect your business. Most IT
organizations don't have a clear picture of how application
performance affects their revenue. With AppDynamics, you get 100%
visibility into your Java,.NET, & PHP application. Start your
15-day FREE TRIAL of AppDynamics Pro!
http://pubads.g.doubleclick.net/gampad/clk?id=84349831&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Geoserver-users mailing list Geoserver-users@lists.sourceforge.net
