On Fri, Oct 3, 2014 at 4:25 PM, Jonathan Moules <J.Moules@anonymised.com>
wrote:
Hi Andrea,
Thanks for the information, that’s interesting and not something I knew; I
tried the monitoring extension quite a while ago but don’t recall an audit
mode; in fact I’m sure it wasn’t as comprehensive in function last time I
looked, but that was 2 years ago.
Unfortunately I don’t have a GeoServer install to play with any more, I
don’t suppose you happen to have any sample logs to hand that you can send
me so I could try parsing them in my logging thing (I see in the docs
they’re XML! :-S )?
I don't have any handy, but the thing is driven by a Freemarker template,
so you can do XML, CSV, JSON, and pretty much whatever other text format
you want
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
