[Geoserver-users] Geoserver v1.5.3 & 900913
Hi Guys,
I tested v1.5.2-rc1 and now v1.5.3 with 900913 (aka spherical mercator)… Unfortunately I can’t see 900913 aligning with google like it should. I tested this with OpenLayers and have a sucessful overlay already using mapserver.
Not sure what more info I can give, or how I can help out…
Andrew Hughes ha scritto:
Hi Guys,
I tested v1.5.2-rc1 and now v1.5.3 with 900913 (aka spherical mercator).... Unfortunately I can't see 900913 aligning with google like it should. I tested this with OpenLayers and have a sucessful overlay already using mapserver.
Andrew,
any chance you can give me a sample dataset and an image generated
with mapserver that has the correct alignment? Private mail would
be ok, I won't divulge the dataset.
I’m having similar problems as well. Geoserver now recognizes the 900913 projection when using the trunk version (from 8/13/07), but when I overlay my layers with Google, I’m getting a unexpected results. My layers are in NAD83. I did notice some warnings being reported by the server:
14 Aug 22:17:20 WARN [org.geotools] - Ambiguity between inverse flattening and semi minor axis length. Using inverse flattening.
I don’t know if this helps, but here is an example of the shift that I’m seeing:
GoogleMercator Point (lat/lon): 4738637.1308, -9402595.2850
Geoserver Point`` (lat/lon)`` : 4723196.8511, -9371065.0109
Andrea Aime wrote:
__________________________________
Jeremy Nix
Senior Application Developer
Southwest Financial Services, Ltd.
(513) 621-6699
Hi Guys,
Andrew,
Still grepping through log files to find problems?  Stop.
Download your FREE copy of Splunk now >>  [http://get.splunk.com/](http://get.splunk.com/)
Geoserver-users mailing list
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
Jeremy Nix ha scritto:
I'm having similar problems as well. Geoserver now recognizes the 900913 projection when using the trunk version (from 8/13/07), but when I overlay my layers with Google, I'm getting a unexpected results. My layers are in NAD83. I did notice some warnings being reported by the server:
I don't know if this helps, but here is an example of the shift that I'm seeing:
Geoserver Point (lat/lon) : 4723196.8511, -9371065.0109
Jeremy, more than a single point it would be useful to have a sample
dataset (by private mail).
Hi all, I am experiencing the same problem with whatever dataset that are not in EPSG:4326. It seems that geoserver (or openlayer) get lost with reprojection with googlemap projections
gersh
server:
seeing:
gersh
Ok,
I've created a new nightly build which appears to fix Andrew and probably Jeremy issues. Can you all download it from
http://geo.openplans.org/nightly/1.5.x/ (grab the "latest" build),
test it against your data again, and report back?
btw, same problem appears on 1.6beta2
gersh
gersh
Ok,
I’ve created a new nightly build which appears to fix Andrew and
http://geo.openplans.org/nightly/1.5.x/ (grab the “latest” build),
Of course it does, beta2 is even older than 1.5.2.
I need to know if it still happens in the nightly I pointed out,
that's where I may have fixed it.
Ok, i tried, but i met another problem:
my projection is not in the proj list (ETRS89-LAEA which is strange since it is a european standard). Before i updated the epsg.properties. but in your snapshot, geoserver does not seem to find it. Is there a new way to add your own projection?
gersh
that’s where I may have fixed it.
Tried with other data, now the google map shows the data ok.
but still my question in my previeous mail (epsg.properties not taken in account?) is pending.
gersh
gersh
No, the way is the same, modify the epsg.properties in the data dir,
then restart GeoServer (the provider won't notice the file
has been updated at runtime).
Just tried with my local version, I added 900914 (as a copy of 900913)
to the user_projections/epsg.properties and it's there in the SRS list after the restart...
Not for this one. Lambert Azimutal Equal Area projection is a projection
we don't have the math for in GeoServer 1.5.x..
The projection has been added in GeoTools, the library we depend on for
most of the work, in the fore coming 2.4.0 release, which is used
by GeoServer 1.6.0 series (still unreleased, that one too).
I just picked its definition from the GeoServer 1.6.x branch, here it is:
PROJCS["ETRS89 / ETRS-LAEA",
   GEOGCS["ETRS89",
     DATUM["European Terrestrial Reference System 1989",
       SPHEROID["GRS 1980", 6378137.0, 298.257222101, AUTHORITY["EPSG","7019"]],
       TOWGS84[0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0],
       AUTHORITY["EPSG","6258"]],
     PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
     UNIT["degree", 0.017453292519943295],
     AXIS["Geodetic longitude", EAST],
     AXIS["Geodetic latitude", NORTH],
     AUTHORITY["EPSG","4258"]],
   PROJECTION["Lambert Azimuthal Equal Area", AUTHORITY["EPSG","9820"]],
   PARAMETER["latitude_of_center", 52.0],
   PARAMETER["longitude_of_center", 10.0],
   PARAMETER["false_easting", 4321000.0],
   PARAMETER["false_northing", 3210000.0],
   UNIT["m", 1.0],
   AXIS["Easting", EAST],
   AXIS["Northing", NORTH],
   AUTHORITY["EPSG","3035"]]
So, if you need it, I advise you grab a GeoServer 1.6.x nightly (starting from today late afternoon, european time, since that
nightly still have to be generated and you need the same fix
that I put in 1.5.x):
http://geo.openplans.org/nightly/trunk/
Andrea Aime
for me it doe not work. I tried 900914, and it says:
Could not find an SRS Authority that understands your SRS. Please verify that your SRS is correct - you might need to consult the SRS authority plug ins to ensure that your SRS is listed.
No code “EPSG:900914” from authority “European Petroleum Survey Group” found for object of type “CoordinateReferenceSystem”.
EPSG:900914
here the line i added in epsg.properties:
900914=PROJCS[“ETRS89 / ETRS-LAEA”,GEOGCS[“ETRS89”,DATUM[“European Terrestrial Reference System 1989”,SPHEROID[“GRS 1980”, 6378137.0, 298.257222101,AUTHORITY[“EPSG”,“7019”]],TOWGS84[ 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0],AUTHORITY[“EPSG”,“6258”]],PRIMEM[“Greenwich”, 0.0,AUTHORITY[“EPSG”,“8901”]],UNIT[“degree”, 0.017453292519943295],AXIS[“Geodetic longitude”, EAST],AXIS[“Geodetic latitude”, NORTH],AUTHORITY[“EPSG”,“4258”]],PROJECTION[“Lambert Azimuthal Equal Area”, AUTHORITY[“EPSG”,“9820”]],PARAMETER[“latitude_of_center”, 52.0],PARAMETER[“longitude_of_center”, 10.0],PARAMETER[“false_easting”, 4321000.0],PARAMETER[“false_northing”, 3210000.0],UNIT[“m”, 1.0],AXIS[“Easting”, EAST],AXIS[“Northing”, NORTH],AUTHORITY[“EPSG”,“3035”]]
any idea. It seems that is checking another file, or forget to check it.
gersh
we don’t have the math for in GeoServer 1.5.x…
GEOGCS[“ETRS89”,
PRIMEM[“Greenwich”, 0.0, AUTHORITY[“EPSG”,“8901”]],
UNIT[“m”, 1.0],
Andrea Aime
    No code "EPSG:900914" from authority "European Petroleum Survey
    Group" found for object of type "CoordinateReferenceSystem".
    EPSG:900914
Tried means doing a GetMap? What if you list the SRS known by GeoServer?
(http://localhost:8080/geoserver/srsHelp.do, and be patient, the list
is very long and the everything in a single page very dumb...)
    900914=PROJCS["ETRS89 / ETRS-LAEA",GEOGCS["ETRS89",DATUM["European
    Terrestrial Reference System 1989",SPHEROID["GRS 1980", 6378137.0,
    298.257222101,AUTHORITY["EPSG","7019"]],TOWGS84[ 0.0, 0.0, 0.0, 0.0,
    0.0, 0.0, 0.0],AUTHORITY["EPSG","6258"]],PRIMEM["Greenwich",
    0.0,AUTHORITY["EPSG","8901"]],UNIT["degree",
    0.017453292519943295],AXIS["Geodetic longitude",
    EAST],AXIS["Geodetic latitude",
    NORTH],AUTHORITY["EPSG","4258"]],PROJECTION["Lambert Azimuthal Equal
    Area", AUTHORITY["EPSG","9820"]],PARAMETER["latitude_of_center",
    52.0],PARAMETER["longitude_of_center",
    10.0],PARAMETER["false_easting",
    4321000.0],PARAMETER["false_northing", 3210000.0],UNIT["m",
    1.0],AXIS["Easting", EAST],AXIS["Northing",
    NORTH],AUTHORITY["EPSG","3035"]]
I hope this is all in one line, right? Otherwise it won't work.
May it be that you're modifying the wrong Geoserver data directory?
During GeoServer startup there is a log stating the current data dir,
on my pc I read:
2007-08-16 16:40:37.312:/geoserver:INFO: Loading Spring root WebApplicationContext
- GEOSERVER_DATA_DIR: C:\progetti\geoserver\src\1.5.x\configuration\release
ok seems that 1.5.x cannot find a transformation for Lambert Azimuthal Equal Area
I downloaded the 1.6.x nightly builds and it works perfect
cheers,
Fix
EPSG:900914
is very long and the everything in a single page very dumb…)
0.0, 0.0, 0.0 ],AUTHORITY[“EPSG”,“6258”]],PRIMEM[“Greenwich”,
I hope this is all in one line, right? Otherwise it won’t work.
May it be that you’re modifying the wrong Geoserver data directory?
on my pc I read:
  • GEOSERVER_DATA_DIR: C:\progetti\geoserver\src\1.5.x\configuration\release
