Hi Daniele,
Sorry for the slow response.
After creating a sample non-overlapping data set, I may have got the answer I needed; that the granules comprising the layer should not overlap when using the inset feature.
With no overlap (and footprints not overlapped) the gaps do not appear at small scales and inset property set.
With the overlap (and footprints overlapped) the gaps do show up. I have attached a couple of screen shots (they aren’t that great, given my test data). But, if you look at the middle of example-overlap.jpg you’ll see the gap forming.
Thanks.
Lonnie
On Wed, Jul 8, 2015 at 7:37 PM, Lonnie Matsuno <lonnie.matsuno@anonymised.com> wrote:
I have a question regarding the Geoserver vector footprints.
Reading the documentation, there is are propeties footprint_inset_type=full/border and footprint_inset. If “border” is chosen, then should the tiles comprising the mosaic be butt matched?
I am observing in 2.7.1 that if the tiles have overlap and the inset / border property is used then gaps open up at small scales between the tiles.
Thanks.
Lonnie
Don’t Limit Your Business. Reach for the Cloud.
GigeNET’s Cloud Solutions provide you with the tools and support that
you need to offload your IT needs and focus on growing your business.
Configured For All Businesses. Start Your Cloud Today.
https://www.gigenetcloud.com/
Geoserver-users mailing list
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
