[Geoserver-users] GeoServer w/ CAS Performance
I currently have a system with CAS single sign on integrated. I noticed that with CAS enabled my OGC requests are taking ~100ms longer to get a response. Is this expected? I would expect that only the initial request would get a hit, but for me all my requests are taking the hit.
Danny
Hy Danny
Please check the log file of the CAS Server. There you can see the incoming requests and check if each GeoServer request triggers a CAS request.
Christian
On Sun, Oct 18, 2015 at 4:34 AM, Danny Cheng <dcheng@anonymised.com> wrote:
Danny
Geoserver-users mailing list
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
Christian,
thinking out loud here, we normally setup OGC services so that they don’t create a session
because of the many clients hitting the server and the cost of keeping sessions.
However, for stuff like CAS where an authentication can make us do a network call, would it be better
to advise allowing session creation instead? Or do we have other caching strategies?
This is more of a general question, it may or not related to Danny’s problem
On Sun, Oct 18, 2015 at 3:18 PM, Christian Mueller <christian.mueller@anonymised.com> wrote:
Hy Danny
Christian
Danny
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Andrea
For stateless authentication we have a cache to avoid the overhead for each request.
Additionally, you can allow session creation for each filter chain individually (in this case the cache is not used).
I am waiting for the reply of Danny, maybe there is a bug.
Christian
On Mon, Oct 19, 2015 at 9:54 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Christian,
Hy Danny
Christian
Ing. Andrea Aime
@geowolf
Technical Lead
Danny
Hi Christian,
I checked the log and have confirmed that only the initial GeoServer request is hitting CAS – which is good. Maybe the 100ms difference with CAS on/off is just an one-off result.
Danny
Hi Andrea
Christian
On Mon, Oct 19, 2015 at 9:54 AM, Andrea Aime <andrea.aime@…1107…> wrote:
Christian,
On Sun, Oct 18, 2015 at 3:18 PM, Christian Mueller <christian.mueller@…5445…> wrote:
Hy Danny
Christian
On Sun, Oct 18, 2015 at 4:34 AM, Danny Cheng <dcheng@…3836…> wrote:
Danny
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Danny
Is your configuration without CAS a public configuration meaning no security at all. ?
Does it make a difference if you use basic auth instead of CAS ?
Normally, the initial request should last longer.
Christian
On Mon, Oct 19, 2015 at 8:15 PM, Danny Cheng <dcheng@anonymised.com> wrote:
Hi Christian,
Danny
From: Christian Mueller [mailto:christian.mueller@anonymised.com]
Sent: Monday, October 19, 2015 7:43 AM
To: Andrea Aime
Cc: Danny Cheng; geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] GeoServer w/ CAS Performance
Hi Andrea
Christian
On Mon, Oct 19, 2015 at 9:54 AM, Andrea Aime <andrea.aime@anonymised.com7…> wrote:
Christian,
Hy Danny
Christian
Danny
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Christian:
Yes, my configuration without CAS meant no security at all. I would think basic authentication would be faster? Also, I guess it’s worth mentioning that our CAS server is on a separate machine apart from where we have GeoServer installed. Of course, I haven’t actually done the test to verify this, but that’s my assumption.
Danny
Hi Danny
Christian
On Mon, Oct 19, 2015 at 8:15 PM, Danny Cheng <dcheng@…3836…> wrote:
Hi Christian,
Danny
From: Christian Mueller [mailto:christian.mueller@…5445…]
To: Andrea Aime
Hi Andrea
Christian
Christian,
Hy Danny
Christian
Danny
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Danny
Basic authentication is only a transport protocol for credentials, it does no authentication. A separate security provider (e. g. LDAP, SQL Database,…) is required to perform authentication. CAS does authentication. The performance is dependent on your configuration.
The 100ms is the security payload, this is independent of the used authentication mechanism.
Christian
On Fri, Oct 23, 2015 at 10:09 PM, Danny Cheng <dcheng@anonymised.com> wrote:
Hi Christian:
Danny
Sent: Tuesday, October 20, 2015 2:07 AM
To: Danny Cheng
Cc: Andrea Aime; geoserver-users@lists.sourceforge.net
Hi Danny
Christian
Hi Christian,
Danny
To: Andrea Aime
Hi Andrea
Christian
Christian,
Hy Danny
Christian
Danny
Ing. Andrea Aime
@geowolf
Technical Lead
