[Geoserver-users] geoserver war broken in tomcat 8.0.24
We recently upgraded to tomcat 8.0.24 and this broke our geoserver. We are currently using geoserver 2.5.2, but I also test this on the newest geoserver 2.7.1.1 and it is also an issue. It works in tomcat 8.0.23 but not 24.
You get the following error:
 SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.listenerStart Exception sending context initialized event to listener instance of class org.geoserver.GeoserverInitStartupListener
 java.util.ServiceConfigurationError: javax.imageio.spi.ImageWriterSpi: Provider com.sun.media.imageioimpl.plugins.jpeg.CLibJPEGImageWriterSpi could not be instantiated
	at java.util.ServiceLoader.fail(ServiceLoader.java:232)
	at java.util.ServiceLoader.access$100(ServiceLoader.java:185)
	at java.util.ServiceLoader$LazyIterator.nextService(ServiceLoader.java:384)
	at java.util.ServiceLoader$LazyIterator.next(ServiceLoader.java:404)
	at java.util.ServiceLoader$1.next(ServiceLoader.java:480)
	at javax.imageio.spi.IIORegistry.registerApplicationClasspathSpis(IIORegistry.java:210)
	at javax.imageio.spi.IIORegistry.<init>(IIORegistry.java:138)
	at javax.imageio.spi.IIORegistry.getDefaultInstance(IIORegistry.java:159)
	at javax.imageio.ImageIO.<clinit>(ImageIO.java:66)
	at org.geoserver.GeoserverInitStartupListener.contextInitialized(GeoserverInitStartupListener.java:159)
	at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4729)
	at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5167)
	at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
	at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:725)
	at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:701)
	at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:717)
	at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:945)
	at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1768)
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
	at java.util.concurrent.FutureTask.run(FutureTask.java:266)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
	at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.IllegalArgumentException: vendorName == null!
	at javax.imageio.spi.IIOServiceProvider.<init>(IIOServiceProvider.java:76)
	at javax.imageio.spi.ImageReaderWriterSpi.<init>(ImageReaderWriterSpi.java:231)
	at javax.imageio.spi.ImageWriterSpi.<init>(ImageWriterSpi.java:213)
	at com.sun.media.imageioimpl.plugins.jpeg.CLibJPEGImageWriterSpi.<init>(CLibJPEGImageWriterSpi.java:84)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
	at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
	at java.lang.reflect.Constructor.newInstance(Constructor.java:422)
	at java.lang.Class.newInstance(Class.java:442)
	at java.util.ServiceLoader$LazyIterator.nextService(ServiceLoader.java:380)
	... 20 more
I tried a couple different fixes, but what ended up working was moving all the jai_*.jar files to the tomcat lib dir.
Obviously this is less than ideal and was wondering if there was a more permanent fix?  I have looked through the change log for 8.0.24 to see what would have broken it and didn’t not see anything that looked like it was the culprit.
Josh Moore
Information Program Analyst
Flight Inspection Services
AJW-391
(Office) 405-954-4314
(Cell) 405-397-9048
joshua.d.moore@anonymised.com
for the record, this one has been confirmed as a regression in Tomcat, and has been fixed, I believe the fix
should be out in 8.0.25 and 7.0.63:
https://bz.apache.org/bugzilla/show_bug.cgi?id=58192
	... 20 more
Josh Moore
AJW-391
(Cell) 405-397-9048
Don’t Limit Your Business. Reach for the Cloud.
GigeNET’s Cloud Solutions provide you with the tools and support that
you need to offload your IT needs and focus on growing your business.
Configured For All Businesses. Start Your Cloud Today.
https://www.gigenetcloud.com/
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
