[Geoserver-users] geoserver war broken in tomcat 8.0.24
Further to Joshua’s message earlier in the month, I too ran into this issue on Tomcat 8.0.24 with GeoServer 2.7.1.1, 2.7.0, 2.6.4 and 2.6.2. I have for now moved to Tomcat 8.0.23.
This install is running on Windows Server 2012 R2, Oracle Java SE 7.0.800.15.
Matt.
Date: Fri, 10 Jul 2015 17:31:54 +0000
Subject: [Geoserver-users] geoserver war broken in tomcat 8.0.24
To: <geoserver-users@lists.sourceforge.net>
Message-ID: <D1C5691D.F705%joshua.d.moore@anonymised.com>
Content-Type: text/plain; charset=“windows-1252”
We recently upgraded to tomcat 8.0.24 and this broke our geoserver. We are currently using geoserver 2.5.2, but I also test this on the newest geoserver 2.7.1.1 and it is also an issue. It works in tomcat 8.0.23 but not 24.
You get the following error:
SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.listenerStart Exception sending context initialized event to listener instance of class org.geoserver.GeoserverInitStartupListener
java.util.ServiceConfigurationError: javax.imageio.spi.ImageWriterSpi: Provider com.sun.media.imageioimpl.plugins.jpeg.CLibJPEGImageWriterSpi could not be instantiated
at java.util.ServiceLoader.fail(ServiceLoader.java:232)
at java.util.ServiceLoader.access$100(ServiceLoader.java:185)
at java.util.ServiceLoader$LazyIterator.nextService(ServiceLoader.java:384)
at java.util.ServiceLoader$LazyIterator.next(ServiceLoader.java:404)
at java.util.ServiceLoader$1.next(ServiceLoader.java:480)
at javax.imageio.spi.IIORegistry.registerApplicationClasspathSpis(IIORegistry.java:210)
at javax.imageio.spi.IIORegistry.(IIORegistry.java:138)
at javax.imageio.spi.IIORegistry.getDefaultInstance(IIORegistry.java:159)
at javax.imageio.ImageIO.(ImageIO.java:66)
at org.geoserver.GeoserverInitStartupListener.contextInitialized(GeoserverInitStartupListener.java:159)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4729)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5167)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:725)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:701)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:717)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:945)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1768)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.IllegalArgumentException: vendorName == null!
at javax.imageio.spi.IIOServiceProvider.(IIOServiceProvider.java:76)
at javax.imageio.spi.ImageReaderWriterSpi.(ImageReaderWriterSpi.java:231)
at javax.imageio.spi.ImageWriterSpi.(ImageWriterSpi.java:213)
at com.sun.media.imageioimpl.plugins.jpeg.CLibJPEGImageWriterSpi.(CLibJPEGImageWriterSpi.java:84)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:422)
at java.lang.Class.newInstance(Class.java:442)
at java.util.ServiceLoader$LazyIterator.nextService(ServiceLoader.java:380)
… 20 more
I tried a couple different fixes, but what ended up working was moving all the jai_*.jar files to the tomcat lib dir.
Obviously this is less than ideal and was wondering if there was a more permanent fix? I have looked through the change log for 8.0.24 to see what would have broken it and didn?t not see anything that looked like it was the culprit.
Josh Moore
Information Program Analyst
Flight Inspection Services
AJW-391
(Office) 405-954-4314
(Cell) 405-397-9048
joshua.d.moore@anonymised.com<mailto:joshua.d.moore@anonymised.com.
from the looks of it, Tomcat devs are again breaking apps using JAI and JAI ImageIO.
They did it in the past already, you should report a bug against them, not sure
there is anything we can do, and the regression is clearly on their side (we are simply
calling the init of the ImageIO subsystem…)
On Mon, Jul 20, 2015 at 1:42 PM, Matt Walker <walkermatt@anonymised.com> wrote:
Matt.
Don’t Limit Your Business. Reach for the Cloud.
GigeNET’s Cloud Solutions provide you with the tools and support that
you need to offload your IT needs and focus on growing your business.
Configured For All Businesses. Start Your Cloud Today.
https://www.gigenetcloud.com/
Geoserver-users mailing list
… 20 more
Josh Moore
AJW-391
(Cell) 405-397-9048
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
