Create jira task 746: http://jira.codehaus.org/browse/GEOS-746
Because there is no WCS component in jira I filed it under 'unknown'.
V.
> Hi Alessio,
> I think I would make sense to have similar behaviour for all file based
> stores, and I do like the behaviour of featureStore. I'll try to file a
> jira task on this (will be my first one ever for geoserver :)).
>> Hi Vincent,
>> thank you very much for your help and testing ... I built the WCS
>> module thinking that all files should be relative to the GEOSERVER
>> DATA DIR, so this is not a bug on the actual interface. However if
>> people need to access coverages outside the DATA DIR too, I think
>> should not be a problem to do this improvement. I think is a good idea
>> to open a Jira task about that, however.
>> On 10/18/06, *Vincent Schut* <schut@anonymised.com
>> <mailto:schut@anonymised.com>> wrote:
>> OK, so I think I found the culprit.
>> For coverageStores, the file url handler does *not* handle absolute
>> filenames correctly, or at least not as I understood it should.
>> What I thought it should do is: for file url's that don't start
>> with a
>> slash (relative filenames), append them to GEOSERVER_DATA_DIR, and for
>> those that *do* start with a slash, use them as absolute
>> filenames. This
>> is at least the behaviour for FeatureStores. However, no matter what,
>> all file url's for coveragestores are seen as relative to the
>> geoserver
>> data dir, so files that reside outside this dir can never be found.
>> Should I open a jira issue on this?
>> Vincent.
>> -------- Original Message --------
>> From: Vincent Schut <schut@anonymised.com <mailto:schut@anonymised.com>>
>> To: Alessio Fabiani <alessio.fabiani@anonymised.com
>> <mailto:alessio.fabiani@anonymised.com>>
>> Subject: Re:[Geoserver-devel] [Geoserver-users] geoserver-wcs:
>> connection parameters are invalid error for every CoverageStore
>> Date: 10/18/2006 12:01 PM
>> > Decided to try to deploy geoserver on another linux computer.
>> > Surprisingly, on this pc all works fine (except for the gtopo
>> character
>> > case thingy of course, see previous email). So the problem has
>> something
>> > to do with the local linux install probably... Don't ask me what,
>> > however. Main differences that I can think of are: amd64
>> (working), i586
>> > (not working correctly) and utf8 (working) non-utf8 system (not
>> > working). Java versions are the same, distro's are the same.
>> Let's close
>> > the issue for the time being (the previous test pc was not our main
>> > server, so I have hopes to be able to deploy to our main web server
>> > later without problems...). When the problem arises again, of course
>> > I'll mail the list.
>> > This however stresses the importance of informational error
>> messages.
>> > The only message I got, even after enabling the most verbose
>> logging,
>> > was "Unable to get an ImageInputStream". That's pretty hard to
>> debug for
>> > a non geoserver core developer...
>> > Anyways, glad things seem to work now. Keep up the good work!
>> > Vincent.
>> > From: "Alessio Fabiani" < alessio.fabiani@anonymised.com
>> > To: "Alexander Petkov" <greenkov@anonymised.com
>> <mailto:greenkov@anonymised.com>>
>> > Subject: Re:[Geoserver-users] [Geoserver-devel] geoserver-wcs:
>> > Date: 10/17/2006 09:21 PM
>> >> Thanks Alex, I'm going to do some testing too very soon!
>> >> On 10/17/06, *Alexander Petkov* <greenkov@anonymised.com
>> >> <mailto:greenkov@anonymised.com>> wrote:
>> >> It seems to work on Linux OS.
>> >> 1. I downloaded and installed jdk1.5.0_06 , JAI and jai-imageIO
>> >> 2. I downloaded and extracted tomcat 5.5.20
>> >> 3. I built a geoserver war with "mvn -Dmaven.test.skip
>> clean install"
>> >> from today's SVN.
>> >> 4. Moved geoserver.war to tomcat's webapps subdirectory
>> >> 5. Started and stopped tomcat.
>> >> 5. Deleted geoserver/data subdirectory
>> >> 6. Defined GEOSERVER_DATA_DIR variable in geoserver's
>> web.xml as
>> >> described here:
>> http://docs.codehaus.org/display/GEOSDOC/GeoServer+Data+Directory
>> http://docs.codehaus.org/display/GEOSDOC/GeoServer+Data+Directory>
>> >> (for some reason exporting the env. variable did not work,
>> maybe
>> >> catalina.sh needs to be modified).
>> >> 7. Started tomcat.
>> >> Configuring new coverageStores and coverages seemed to work
>> (I got
>> >> a map).
>> >> The only thing I see as not working so far is using the
>> exported
>> >> GEOSERVER_DATA_DIR from the shell, but I might be wrong on
>> that one.
>> >> Other than that, geoserver WCS seems to behave as expected
>> under
>> >> tomcat in a Linux environment.
>> >> Alex
>> >> On 10/17/06, Simone Giannecchini < simboss1@anonymised.com
>> <mailto:simboss1@anonymised.com>
>> >> <mailto:simboss1@anonymised.com>> wrote:
>> >> > That would be *great*!
>> >> > Simone.
>> >> > On 10/17/06, Alexander Petkov < greenkov@anonymised.com
>> >> <mailto: greenkov@anonymised.com <mailto:greenkov@anonymised.com>>>
>> wrote:
>> >> > > I cna start doing some of this testing in a Linux OS, since
>> >> that is
>> >> > > all I have and use in production. So far I don't think
>> I have
>> >> seen the
>> >> > > behaviour described in this thread, and if I have, I
>> probably
>> >> changed
>> >> > > the startup scripts :-).
>> >> > > For some reason I prefer using jetty, but I can try with
>> >> tomcat too.
>> >> > > Alex
>> >> > > On 10/17/06, Fabio Da Soghe <fabio.dasoghe@anonymised.com
>> <mailto:fabio.dasoghe@anonymised.com>
>> <mailto:fabio.dasoghe@anonymised.com>>> wrote:
>> >> > > > Thank you for your work!
>> >> > > > I'll wait for your tests on linux environment. In the
>> >> meanwhile I'll do a
>> >> > > > try on windows, just to verify I'm able to correctly
>> install
>> >> geoserver-wcs
>> >> > > > and all its dependecies.
>> >> > > > Hope to read from you soon.
>> >> > > > Cheers,
>> >> > > > Fabio
>> >> > > > Simone Giannecchini ha scritto:
>> >> > > > Ciao all,
>> >> > > > as Alessio correctly pointed out, we spend most part
>> of our
>> >> time
>> >> > > > working in a windows-only environment. We had a
>> linux box
>> >> doing builds
>> >> > > > for us but in the last couple of month we have fried
>> >> already two
>> >> > > > machines. It is exactly 3 weeks that we are not
>> testing on
>> >> linux, but
>> >> > > > this weekend we will set up a new linux box for testing
>> >> purposes.
>> >> > > > Anyway, thanks everybody for testing and reporting
>> issues.
>> >> > > > Simone.
>> >> > > > On 10/17/06, Alessio Fabiani
>> <alessio.fabiani@anonymised.com <mailto:alessio.fabiani@anonymised.com>
>> >> <mailto: alessio.fabiani@anonymised.com
>> <mailto:alessio.fabiani@anonymised.com>>> wrote:
>> >> > > > Hi all guys,
>> >> > > > GeoServer WCS actually isn't tested deeply on a Linux
>> >> environment, so I'm
>> >> > > > not surprised of strange behaviors ... however we are
>> >> working on setting up
>> >> > > > last WCS changes on a Fedora server.
>> >> > > > As soon we succeded with the configuration we will
>> post a
>> >> detailed tutorial
>> >> > > > on how to install and configure GeoServer WCS on
>> linux OS.
>> >> > > > Any help, comment and whatever is appreciated, of
>> course.
>> >> > > > On 10/17/06, Vincent Schut < schut@anonymised.com
>> >> > > > > Thanks Fabio for your reaction. See inline for my
>> comments.
>> >> > > > > From: Fabio Da Soghe < fabio.dasoghe@anonymised.com
>> >> > > > > To: geoserver-users@lists.sourceforge.net
>> <mailto:geoserver-users@lists.sourceforge.net>
>> <mailto:geoserver-users@lists.sourceforge.net>>,
>> >> > > > Geoserver-devel
>> >> > > > > < geoserver-devel@lists.sourceforge.net
>> <mailto:geoserver-devel@lists.sourceforge.net>
>> <mailto:geoserver-devel@lists.sourceforge.net>>>
>> >> geoserver-wcs:
>> >> CoverageStore
>> >> > > > > Date: 10/17/2006 03:59 PM
>> >> > > > > > Hi Vincent.
>> >> > > > > > I had a very similar problem (I posted yesterday
>> on the
>> >> user list about
>> >> > > > > > that).
>> >> > > > > > The message error I got was:
>> >> > > > > > Internal error : unable to get reader for this
>> coverage
>> >> layer
>> >> > > > > > Then I followed Alessio Fabiani's hint to update JAI
>> >> and ImageIO to the
>> >> > > > > > very last version (JAI 1.1.4 and imageio 1.1): after
>> >> this GeoServer
>> >> > > > > > didn't load correctly the raster plugins at startup.
>> >> > > > > Hmm. I'm using pretty recent cvs versions of JAI and
>> >> JAI-IO. I thought
>> >> > > > > that was more or less a prerequisite for geoserver-wcs
>> >> instead of a
>> >> > > > > blocker...
>> >> > > > > I'll look further into it tomorrow, have to go now.
>> >> Strange thing is I
>> >> > > > > succeed with *some* coverages to configure them,
>> but for
>> >> some I get the
>> >> > > > > error.
>> >> > > > > OK, any hints apreciated, especially about how to
>> get a
>> >> bit more useful
>> >> > > > > error info from geoserver... More new (hopefully)
>> tomorrow.
>> >> > > > > Cheers for now,
>> >> > > > > Vincent.
>> >> > > > > > My configuration is:
>> >> > > > > > - linux fedora core 4
>> >> > > > > > - Java 1.5.0_06 (Sun)
>> >> > > > > > - JAI 1.1.4 pre-dr-b03
>> >> > > > > > - ImageIO 1.1 beta
>> >> > > > > > - Tomcat 5.5
>> >> > > > > > I used the geoserver-1.4.0-M2-WCS binary build. What
>> >> version of JAI and
>> >> > > > > > ImageIO do you have? Maybe you could be more
>> fortunate
>> >> then me with an
>> >> > > > > > update...
>> >> > > > > > Hope this helps.
>> >> > > > > > Cheers,
>> >> > > > > > Fabio
>> >> > > > > > Vincent Schut ha scritto:
>> >> > > > > >> Hi list, dev's,
>> >> > > > > >> I'm trying to set up geoserver-1.4.x-merge-wcs (svn
>> >> from today). For
>> >> > > > > >> feature data (shape, postgis) all is OK, but if
>> I want
>> >> to define a new
>> >> > > > > >> CoverageStore I get an "Connection Parameters are
>> >> invalid" message on
>> >> > > > > >> submitting, no matter if I use an abolute or a
>> >> relative url for the
>> >> > > > > >> data. I get this message even with the demo
>> coverages
>> >> (Gtopo30,
>> >> > > > > >> sample_geotiff, etc), so I guess it is not me
>> entering
>> >> wrong
>> >> > > > filenames,
>> >> > > > > >> but something inside geoserver is not entirely
>> right.
>> >> Nothing is
>> >> > > > logged
>> >> > > > > >> (I have enabled the logs/geoserver.log, and the
>> file
>> >> has been
>> >> > > > created),
>> >> > > > > >> so I have no idea where to start resolving this...
>> >> > > > > >> Btw I am using a GEOSERVER_DATA_DIR outside of the
>> >> exploded war
>> >> > > > > >> (tomcat). It is defined as a environment
>> variable, and
>> >> is picked up
>> >> > > > > >> alright, proven with shapefiles, config
>> (catalog.xml,
>> >> services.xml)
>> >> > > > and
>> >> > > > > >> the log file.
>> >> > > > > >> Environment: gentoo linux, java sun jdk 1.5,
>> jai and
>> >> jai-imageio
>> >> > > > > >> correctly installed.
>> >> > > > > >> Vincent.
>> >> > > > > >> Using Tomcat but need to do more? Need to
>> support web
>> >> services,
>> >> > > > security?
>> >> > > > > >> Get stuff done quickly with pre-integrated
>> technology
>> >> to make your job
>> >> > > > easier
>> >> > > > > >> Download IBM WebSphere Application Server v.1.0.1
>> >> based on Apache
>> >> > > > Geronimo
>> http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
>> <http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642>
>> <http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642>>
>> >> > > > > >> _______________________________________________
>> >> > > > > >> Geoserver-devel mailing list
>> >> > > > > >> Geoserver-devel@lists.sourceforge.net
>> <mailto:Geoserver-devel@lists.sourceforge.net>
>> <mailto:Geoserver-devel@lists.sourceforge.net>>
>> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
>> >> <https://lists.sourceforge.net/lists/listinfo/geoserver-devel>
>> support web
>> >> services,
>> >> > > > security?
>> technology
>> >> to make your job
>> >> > > > easier
>> v.1.0.1 based
>> >> on Apache
>> >> > > > Geronimo
>> >> > > > > > Geoserver-users mailing list
>> >> > > > > > Geoserver-users@lists.sourceforge.net
>> <mailto:Geoserver-users@lists.sourceforge.net>
>> >> <mailto: Geoserver-users@lists.sourceforge.net
>> <mailto:Geoserver-users@lists.sourceforge.net>>
>> https://lists.sourceforge.net/lists/listinfo/geoserver-users
>> >> > > > > Using Tomcat but need to do more? Need to support web
>> >> services, security?
>> technology to
>> >> make your job
>> >> > > > easier
>> based
>> >> on Apache
>> >> > > > Geronimo
>> >> < https://lists.sourceforge.net/lists/listinfo/geoserver-devel>
>> >> > > > Eng. Alessio Fabiani
>> >> > > > Vice President/CTO GeoSolutions
>> >> > > > http://www.geo-solutions.it
>> >> services, security?
>> >> > > > Get stuff done quickly with pre-integrated technology to
>> >> make your job
>> >> > > > easier
>> based on
>> >> Apache Geronimo
>> >> <https://lists.sourceforge.net/lists/listinfo/geoserver-users>
>> >> services, security?
>> >> make your job
>> >> > > > easier
>> based on
>> >> Apache Geronimo
>> >> services, security?
>> to make
>> >> your job easier
>> >> > > Download IBM WebSphere Application Server v.1.0.1 based on
>> >> Apache Geronimo
>> >> > Eng. Simone Giannecchini
>> >> > President /CEO GeoSolutions
>> services,
>> >> security?
>> make your
>> >> job easier
>> Apache
>> >> Geronimo
>> >> Using Tomcat but need to do more? Need to support web services,
>> security?
>> >> Get stuff done quickly with pre-integrated technology to make
>> your job easier
>> Apache Geronimo
>> security?
>> your job easier
>> Apache Geronimo
>> Using Tomcat but need to do more? Need to support web services, security?
>> Get stuff done quickly with pre-integrated technology to make your job easier
>> Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
