We are using GeoServer 2.4.2 and the web interface has started to act a bit weirdly. We are using IE 11 to load the web interface. I log in as an admin user and the problems I have recently encountered include:
1) The delete links (remove workspace, store, or layer) don't work. If I select one or more items and then click the "Remove selected xxx" link, nothing happens. I do get the popup window if I click on the "Add a new xxx" though. Just no action from a delete.
2) On a new layer form when I click the Find button to get the SRS, the popup box is displayed but it doesn't seem to take any search criteria entry and if I try to scroll down, the popup acts as if I want to resize it.
Very odd behavior which was not happening before. I am not sure if the server had its IE updated to 11 and that is causing the problem or something else. I stop and restarted the GeoServer service but that didn't help.
Any thoughts?
Thanks - Peter
Ciao Peter,
I am not much of an IE user although I work on Win, I will give
GeoServer a more thorough try in the next days.
Ton confirm that this is an IE problem, could do some tests using Chrome or FF?
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
Any thoughts?
Thanks - Peter
Androi apps run on BlackBerry 10
Introducing the new BlackBerry 10.2.1 Runtime for Android apps.
Now with support for Jelly Bean, Bluetooth, Mapview and more.
Get your Android app in front of a whole new audience. Start now.
http://pubads.g.doubleclick.net/gampad/clk?id=124407151&iu=/4140/ostg.clktrk
Geoserver-users mailing list
