[Geoserver-users] Geoserver Web-Mapping
Hello!
The GeoServer project has instructions for running from Eclipse (so I would use that because there is an example to follow).
http://docs.geoserver.org/latest/en/developer/eclipse-guide/
On 8 May 2015 at 14:54, ELKHATTABI Imane <imanekhtb@anonymised.com> wrote:
Hello Jody
I came across one of your posts on the How2map plateform.
I really hope you don’t mind me asking. But I’m in a same situation where i need to run a Geoserver web-mapping project directly from an IDE like Netbeans or Eclipse.
I don’t know witch IDE to use that can easily run Geoserver with libraries (Openlayers, Ext, geoExt)
I’d be very thankful to know how to overcome the problem .
Any hint or help would be highly apreciated.
Best regards
Jody Garnett
