Hello Everyone
I am doing WFS With Geoserver/Sql server 2008
Sql server 2008 Geometry datatype property specifies itself as a
generic “gml:GeometryPropertyType”.
How can i make something more specific like “gml:LineStringPropertyType”.
I’ve seen the spatial fields do this in the past with my
oracle/geoserver setup here, it turned out to be because I did not
have a proper spatial index on my table.
Please let me know how to do for Sql server 2008
Thanks
Sreenath
Hi Sreenath,
You can override the schema produced by geoserver by placing a schema.xsd file into the feature type configuration directory of the feature type you want to override. Perform the following steps:
1) Make a DFT request against teh feature type, and save the result to a file
2) Edit the file manually, changing gml:GeometryPropertyType to gml:LineStringPropertyType
3) Save the file into <data_directory>/featureTypes/<yourFeatureType>/schema.xsd
Now subsequent DescribeFeatureType and GetFeature calls will use this schema instead of generating one from the table.
-Justin
sreenath reddy wrote:
Hello Everyone
Thanks
Sreenath
The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
production scanning environment may not be a perfect world - but thanks to
Kodak, there's a perfect scanner to get the job done! With the NEW KODAK i700
Series Scanner you'll get full speed at 300 dpi even with all image processing features enabled. http://p.sf.net/sfu/kodak-com
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
It is appreciated if you can keep replies on the public list. Thanks
You may have to do a server restart before the new schema properly kicks in. Have you done one?
Hello Justin
Thanks for your reply. I am not getting Schema now.
After following your steps for WFS GetFeature1.1.Xml
<xsd:schema elementFormDefault="qualified" targetNamespace="http://SAE">
<xsd:import namespace="http://www.opengis.net/gml"
schemaLocation="http://localhost:8080/geoserver/schemas/gml/3.1.1/base/gml.xsd"/>
</xsd:schema>
Before following your steps i got
<xsd:complexType name="CecmGeoLocationType">
<xsd:complexContent>
<xsd:extension base="gml:AbstractFeatureType">
<xsd:sequence>
<xsd:element maxOccurs="1" minOccurs="0" name="EventId"
nillable="true" type="xsd:int"/>
<xsd:element maxOccurs="1" minOccurs="0" name="Location"
nillable="true" type="gml:GeometryPropertyType"/>
<xsd:element maxOccurs="1" minOccurs="0" name="EventName"
nillable="true" type="xsd:string"/>
<xsd:element maxOccurs="1" minOccurs="0" name="EventTypeId"
<xsd:element maxOccurs="1" minOccurs="0" name="EventDescription"
<xsd:element maxOccurs="1" minOccurs="0" name="EventStartDate"
nillable="true" type="xsd:dateTime"/>
<xsd:element maxOccurs="1" minOccurs="0" name="EventEndDate"
<xsd:element maxOccurs="1" minOccurs="0" name="EventOtherDetails"
<xsd:element maxOccurs="1" minOccurs="0" name="LocationDetails"
</xsd:sequence>
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
<xsd:element name="CecmGeoLocation" substitutionGroup="gml:_Feature"
type="cecm:CecmGeoLocationType"/>
</xsd:schema>
On Wed, May 13, 2009 at 2:31 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Hi Sreenath,
file
-Justin
Hello Everyone
generic "gml:GeometryPropertyType".
How can i make something more specific like "gml:LineStringPropertyType".
I've seen the spatial fields do this in the past with my
Thanks
Sreenath
i700
Justin Deoliveira
Justin Deoliveira
