Hi Andrea,
I switched Back to the old Geoserver Version (1.7) which works fine even on my new machine.
In my case (using it as WFS-T-Server with Mapbender) Version 1.7 perform its Job very well.
Thanks for your Help
Marc
On Thu, Apr 16, 2015 at 10:37 AM, Manns, Marc <Marc.Manns@…7016…> wrote:
Okay, you are right…
Now i got it…
Here is my output.
Request: getCapabilities
acceptVersions:
version[0] = 1.0.0
baseUrl = http://linux15neu:8080/geoserver/
service = WFS
2015-04-16 10:34:11,268 INFO [geoserver.filters] - 172.20.9.233 “GET /geoserver/wfs?SERVICE=WFS&VERSION=1.0.0&REQUEST=GetCapabilities&TYPENAME=topp:baustellen&SRSNAME=EPSG:31466” took 23ms
2015-04-16 10:34:25,499 INFO [geoserver.filters] - 172.20.9.233 “POST /geoserver/wfs?SERVICE=WFS&VERSION=1.0.0&SRSNAME=EPSG:31466” “Mozilla/5.0 QGIS/2.8.1-Wien” “” request-size: 2921 body:
the_geom<gml:MultiPolygon srsName=“EPSG:31466”>gml:polygonMembergml:Polygongml:outerBoundaryIsgml:LinearRing<gml:coordinates cs=“,” ts=" ">2582689.20000000018626451,5673503.20000000018626451 2582684.5,5673510.79999999981373549 2582683.5,5673511.90000000037252903 2582683.39999999990686774,5673513.79999999981373549 2582684.89999999990686774,5673515 2582691.29999999981373549,5673518.79999999981373549 2582698.70000000018626451,5673523.20000000018626451 2582708.20000000018626451,5673527.09999999962747097 2582713,5673528.5 2582717.10000000009313226,5673529.40000000037252903 2582722.02615281473845243,5673536.79538874141871929 2582730.29999999981373549,5673530.40000000037252903 2582737.39999999990686774,5673530.40000000037252903 2582761.70000000018626451,5673530.5 2582763.29999999981373549,5673530.5 2582782.20000000018626451,5673530.70000000018626451 2582799.10000000009313226,5673530.79999999981373549 2582808.10000000009313226,5673530.79999999981373549 2582820.20000000018626451,5673530.59999999962747097 2582824.5,5673530.09999999962747097 2582849.29999999981373549,5673526.79999999981373549 2582874.10000000009313226,5673523.29999999981373549 2582877.70000000018626451,5673523.5 2582877.70000000018626451,5673521.59999999962747097 2582858.29999999981373549,5673524 2582822.60000000009313226,5673529.09999999962747097 2582810.70000000018626451,5673529.70000000018626451 2582794.79999999981373549,5673529.90000000037252903 2582752.70000000018626451,5673529.29999999981373549 2582745.5,5673529.29999999981373549 2582730,5673529.09999999962747097 2582725.79999999981373549,5673528.90000000037252903 2582717,5673528.09999999962747097 2582708.20000000018626451,5673525.79999999981373549 2582698.70000000018626451,5673521.90000000037252903 2582691,5673517.09999999962747097 2582685,5673513.09999999962747097 2582685.10000000009313226,5673512.09999999962747097 2582685.70000000018626451,5673511.29999999981373549 2582690.70000000018626451,5673503.79999999981373549 2582689.20000000018626451,5673503.20000000018626451</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon>
Thank you. Hmm… this request appears to be valid, not sure why it’s not working.
At this point I suggest you open a ticket at https://osgeo-org.atlassian.net/projects/GEOS with the request, and a sample of the data, just enough
to reproduce the issue on a developer’s machine
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
