Hi Chris,
sorry for the missing software version information:
GeoServer 1.5.1
PostGIS 1.1.2
After a while of searching through log-jungle I picked out some fragments. The SQL query is fine. I tested the query directly and got a response about 500 ms later. By the way, deegree WFS handled the WFS-T requested in about 700 ms; GeoServer needed 1500 ms in the last run. I noticed that there's a warning which points to the xml-parsing process. Maybe that's a fact which could explain a delay? A further question: why does GeoServer perform a SELECT before?
FINE: request is Lock Id: null
releaseAction: ALL
handle: null
Delete Feature Request
feature type:topp:assessmentpoint
filter:[[ damagevalue = 70.4 ] AND [ comment = 2006-01-01;insert WFS test ] AND [ damagecaseid = 5161 ]]
release:true
FINE: SELECT AsText(force_2d(Envelope(Extent("geom"))))
FROM "public"."assessmentpoint"
WHERE ("damagevalue" = 70.4 AND "comment" = '2006-01-01;insert WFS test' AND "damagecaseid" = 5161)
FINE: sql is
SELECT "id", "damagevalue", "date_stamp", "comment", "assessor", "deegree", "damagecaseid", "damageareaid", encode(AsBinary(force_2d("geom"), 'XDR'),'base64')
Jul 11, 2007 5:13:50 PM org.geotools.data.jdbc.JDBC1DataStore executeQuery
FINE: About to execute query:
SELECT "id", "damagevalue", "date_stamp", "comment", "assessor", "damagecaseid", "damageareaid", encode(AsBinary(force_2d("geom"), 'XDR'),'base64')
FINE: sql statment is
DELETE from "public"."assessmentpoint"WHERE ("damagevalue" = 70.4 AND "comment" = '2006-01-01;insert WFS test' AND "damagecaseid" = 5161);
INFO: Service handled
Jul 11, 2007 5:13:51 PM org.vfny.geoserver.util.requests.XmlCharsetDetector getCharsetAwareReader
FINE: First 4 bytes of XML doc are : 3C ('<') 77 ('w') 66 ('f') 73 ('s')
FINE: Charset detection phase 1. Inferred encoding: UTF-8
Jul 11, 2007 5:13:51 PM org.vfny.geoserver.util.requests.XmlCharsetDetector getXmlEncoding
WARNING: Invalid(?) XML declaration: <wfs:T.
FINE: Charset detection phase 2. Charset in XML declaration is `null`.
Jul 11, 2007 5:13:51 PM org.vfny.geoserver.util.requests.XmlCharsetDetector createReader
FINE: Trying to create reader basing on existing charset information: `UTF-8`.
Jul 11, 2007 5:13:51 PM org.vfny.geoserver.util.requests.readers.DispatcherXmlReader getRequest
INFO: getting request type from org.vfny.geoserver.util.requests.DispatcherHandler@anonymised.com
Jul 11, 2007 5:13:51 PM org.vfny.geoserver.servlets.AbstractService doPost
best regards,
Sebastian
Von: Chris Holmes <cholmes@anonymised.com>
Gesendet: 11.07.07 16:13:32
An: Sebastian Paasche <paasche-plaue@anonymised.com>
CC: geoserver-users@lists.sourceforge.net
Betreff: Re: [Geoserver-users] GeoServer WFS-T: poor DELETE performance
Could you put the logging level at FINE and check the logs for the sql
statement that's being executed for DELETE's? Then try out that
statement in postgis directly? And send us what the sql statement is.My guess might be that indexes on the properties you're filtering on
could help. Though there could be something off in the code, if we're
not passing a good sql statement back to the db. Also what version of
GeoServer and PostGIS are you using?thanks,
Chris
Sebastian Paasche wrote:
> Hi all,
> currently I am evaluating the GeoServer according to functionality and performance issues.
> While executing some DELETE Requests to a PostGIS datastore I have to wait unexpectly long for a response.
> The postmaster process runs with 100% on an AMD Opteron 2.2 GHz, but a single
> DELETE request takes still about 1200 ms. By the way, INSERTs are performed well (<20ms).
> Am I doing anything wrong? By which means this process can be accelerated?
> Here is my XML-file which is sent by HTTP Post to the server in a local network:
> <wfs:Transaction service="WFS" version="1.1.0"
> xmlns:wfs="http://www.opengis.net/wfs"
> xmlns:topp="http://www.geoserver.org/topp"
> xmlns:gml="http://www.opengis.net/gml"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:ogc="http://www.opengis.net/ogc"
> xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd http://www.openplans.org/topp http://localhost:8080/geoserver/wfs/">
> <wfs:Delete typeName="topp:assessmentpoint">
> <ogc:Filter>
> <ogc:And>
> <ogc:PropertyIsEqualTo>
> <ogc:PropertyName>topp:damagevalue</ogc:PropertyName>
> <ogc:Literal>70.4</ogc:Literal>
> </ogc:PropertyIsEqualTo>
> <ogc:PropertyName>topp:comment</ogc:PropertyName>
> <ogc:Literal>2006-01-01;insert WFS test</ogc:Literal>
> <ogc:PropertyName>topp:damagecaseid</ogc:PropertyName>
> <ogc:Literal>5161</ogc:Literal>
> </ogc:And>
> </ogc:Filter>
> </wfs:Delete>
> </wfs:Transaction>
> Thanks in advance,
> Sebastian
> _______________________________________________________________________
> Jetzt neu! Schützen Sie Ihren PC mit McAfee und WEB.DE. 3 Monate
> kostenlos testen. http://www.pc-sicherheit.web.de/startseite/?mc=022220
> This SF.net email is sponsored by DB2 Express
> Download DB2 Express C - the FREE version of DB2 express and take
> control of your XML. No limits. Just data. Click to get it now.
> http://sourceforge.net/powerbar/db2/
> Geoserver-users mailing list
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
> !DSPAM:4005,4694aebb238071804284693!
Der WEB.DE SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
http://smartsurfer.web.de/?mc=100071&distributionid=000000000066
