hello everybody,
i've already succeded in adding data as wms to geoserver from postgres,
but got some problems in creating a wfs. hopefully somebody can help me out.
first i added a "web feature server" in datastore and put in
"WFSDataStoreFactory:GET_CAPABILITIES_URL:" the server url
(http://localhost:8080/geoserver/wfs). so far everything is fine.
then i created a new "featuretype" and chose my data with styles etc.
from postgres. altough there's no errors till now, i can't save. if i
try to apply and save the whole configuration (pushed the two buttons on
upperleft) it hangs with:
21 Aug 09:47:57 INFO [geoserver.global] - Loading feature type
'osm_ch_wfs:::HSR_points' (layer 11/21)
21 Aug 09:47:57 INFO [geoserver.wfs] -
Request: getCapabilities
acceptVersions:
version = [1.0.0]
sections = null
acceptFormats = null
updateSequence = null
baseUrl = http://localhost:8080/geoserver/
service = WFS
Result:
i waited half an hour but nothing. what am i doing wrong? somebody got a
hint?
thanks in advance.
regards,
david
What you do is totally different thing that you believe. "Web feature server" datastore means using another external WFS service as source of data (cascading WFS). You want to use your PostGIS as datastore and deliver data from there through Geoserver WFS in a similar way you are already doing through WMS. Actually, if you are aiming to use the same PostGIS data you have everything ready, just start sending WFS requests to your WFS. In standard installation if will be at localhost:8080/geoserver/wfs.
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: geoserver-users-bounces@lists.sourceforge.net puolesta: David Tran
Lähetetty: to 21.8.2008 10:51
Vastaanottaja: geoserver-users@lists.sourceforge.net
Aihe: [Geoserver-users] geoserver - wfs
hello everybody,
acceptVersions:
version = [1.0.0]
sections = null
service = WFS
Result:
hint?
thanks in advance.
regards,
david
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
