After spending time trying to setup the complex datastore branch of Geoserver we stopped after the issues mentioned below. We have installed Deegree which allows you handle complex GML schema types in WFS. This software provides a way to map complex WFS feature types to relational tables. Hope this helps.
Kind regards,
Andy
Hi, they are not really modules... it is more a branch of GeoServer. A
user recently queried the list with the same question (i cant seem to
find it in the archive however so i will just paste it inline here).
Hi Arif,
I've updated instructions on how to get the latest community-schema support
running on this page:
<http://docs.codehaus.org/display/GEOS/Complex+Datastore>
Unfortunately it wont work due to this geotools issue:
<http://jira.codehaus.org/browse/GEOT-1655>\.
I'm sorry about that. Note the community-schemas support in geoserver is
quite
discontinued until sensible funding is thrown up to get it on the core
stream
code base.
Anyway, feel free to try it out if you're willing for a nice debug
session and
keep asking questions on the list.
Best regards,
Dadi, Upendra wrote:
Does anyone know where I can get access to the experimental modules (see below)? Thanks.
Upendra
-----Original Message-----
Sent: Tuesday, January 08, 2008 1:00 PM
To: Dadi, Upendra
Cc: geoserver users; Gabriel Roldán
Subject: Re: [Geoserver-users] postgis wfs insert problemDadi, Upendra ha scritto:
Is there a way to handle complex GML schema types in Geoserver WFS?
How do I handle XML schemas containing anyType (xsd:any) XML element
or <xsd:choice> type element for example ? Does it provide a way to
map complex WFS feature types to relational or object relational tables?
Pointers to any web links dealing with these issues would be greatly
appreciated. Thanks.Released versions of GeoServer only do support simple types. For complex types there actually is an experimental set of modules that do support them, but I'm not able to get into details.
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.net/marketplace
Geoserver-users mailing list
https://lists.sourceforge.net/lists/listinfo/geoserver-users!DSPAM:4007,4783ca12233205210051143!
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
___________________________________________________________________________
Australian Antarctic Division - Commonwealth of Australia
IMPORTANT: This transmission is intended for the addressee only. If you are not the
intended recipient, you are notified that use or dissemination of this communication is
strictly prohibited by Commonwealth law. If you have received this transmission in error,
please notify the sender immediately by e-mail or by telephoning +61 3 6232 3209 and
DELETE the message.
Visit our web site at http://www.antarctica.gov.au/
