Arne,
Thanks - that did it. Now I can keep more hair.
Bryan
-----Original Message-----
Sent: Saturday, April 04, 2009 7:32 AM
To: Hall, Bryan D Contr USAF AFMC 38 EIG/ENC
Subject: Re: [Geoserver-users] GeoServer with GeoWebCache and external
WMS sources
Hi Bryan,
for the GeoServer plugin version you can provide a configuration file
with additional layers (manually defined), called geowebcache.xml [1,2].
In that file you specify the complete URL to the backend server for each
layer, you can also have several backends for the same layer.
Unfortunately, there is a bug in GeoServer 1.7.3a which means you have
to place this file into <geoserver
webapp>/WEB-INF/classes/geowebcache.xml , normally it goes into
<geoserver data dir>/gwc/geowebcache.xml . I hope to provide a fix for
the latter on Monday.
For the free-standing version of GeoWebCache, you can also automatically
fetch layers from two or more servers by editing geowebcache-servlet.xml
[3]. What you have to do is dupliate (cutnpaste) the bean with
id="gwcWMSConfig" (just name the new one gwcWMSConfig2) , and then add
it in the bean with id="gwcTLDispatcher". Note that the server should
not have layers with overlapping names, otherwise it's not really clear
which one you'll end up getting.
Be sure have a look at the logs if you run into any problems.
-Arne
1: http://geowebcache.org/trac/wiki/configuration
2: http://geoserver.org/display/GEOSDOC/5.+GWC+-+GeoWebCache
3:
http://geowebcache.org/trac/browser/tags/1.1.0/geowebcache/src/main/weba
pp/WEB-INF/geowebcache-servlet.xml
Hall, Bryan D Contr USAF AFMC 38 EIG/ENC wrote:
Ok, I'm baffled. Andrea wrote that you can use GWC to fetch wms
services from multiple locations - but I'll be darned if I can figure
out how to do that.
I can easily fetch data from the geoserver that the GWC is "running"
on, but if I try to specify a remote source, GWC says it does not know
about that featuretype.
Example: I first tried setting GWC to pull the tiger-ny layer from the
local geoserver, no problems. I then removed that featuretype on the
local geoserver and pointed the URL to the remove geoserver. It then
said it did not know about that featuretype.
Can someone please provide an example - I must be missing something
here.
Thanks in advance,
Bryan
Arne Kepp
OpenGeo - http://opengeo.org
Expert service straight from the developers
