[Geoserver-users] Geoserver with Mapbuilder
I am using Geoserver with Mapbuilder. How can I change the size of the map displayed? It appears with a predefined size and I have no idea how to change it.
In the source code the tag that displays the map is:
Daniel
Daniel,
In the html page (the one with the <td> tag you copied below) there is a reference to a config.xml file. Take a look inside that config.xml file.
Inside that config.xml file are a couple of lines that look like this (probably right near the top):
<Context id="mainMap">
   <defaultModelUrl>***SOME XML FILE HERE***</defaultModelUrl>
Open the reference xml file (the one that I called "***SOME XML FILE HERE***) and change the lines:
<Window width="570" height="435"/>
To whatever size you like.
Be warned, geoserver *will* stretch the map on the initial load...so if you don't want a "weird" looking map when you start, you'll need to make sure that the width-to-height ratio (from the <Window> tag) and the extent-width-to-extent-height (from the <BoundingBox> tag immediately after the <Window> tag) are exactly the same.
One easy way to do that is to just scale the window size up linearly.
For example:
570x435 = width-to-height ratio of appx 1.31
600x458 = width-to-height ratio of appx 1.31
450x344 = width-to-height ratio of appx 1.31
etc. etc.
--saul
Daniel Ferreira wrote:
<td colspan="2" id="mainMapPane" style="background-color: white;" />
Daniel
