You can just send the email to geoserver-users@lists.sourceforge.net
It is good to register to the mailing list as well so your message goes through right away, otherwise it gets held up in the spam queue where we have to check each message before it gets posted to the list.
For coloring your map in different colors based on some attribute value, check out the style provided by geoserver for the States layer. It is located in your GeoServer data directory underneath styles/. The file you want it called popshade.sld
It will show you how to color different regions.
cheers
Brent Owens
(The Open Planning Project)
Naseer Mohammed Abdul wrote:
hi Brent,
i am trying to post my question on geosever mailing list but i couldnot, so please tell me how to do that...
well i am now comfortable with geoserver and i created a map using shapefile and i am looking for coloring my map with different color in diffirent regions of my map , please help me how to color a map with different color in different regions....
thanks
naseer
On 2/7/07, *Brent Owens* <brentowens@anonymised.com <mailto:brentowens@anonymised.com>> wrote:
It is suggested that you have a separate install of mapbuilder and
just
tell it to talk to your GeoServer instance. This is a good idea if you
want to upgrade geoserver or mapbuilder versions without wiping out
changes you have already made to one or the other.
But if you want to tinker, you can find the mapbuilder libraries under
[geoserver_install]/webapps/geoserver/mb
The source code for the built-in mapbuilder WFS-T demo (the one with
feature editing) can be found under:
[geoserver_install]/webapps/geoserver/wfs-t-demo
You will want to edit the config.xml file to change the buttons and
controls, and you will want to edit the tasmania.xml file to
change what
layers are loaded.
good luck,
Brent Owens
> hi
> i am using geoserver in linux and i am trying to build a web
> application....
> the geoserver provides a default mapbuilder setting and i want to
> change that setting such as locatormap, buttonbar and zoomin zoomout
> buttons, so where i have to make changes to the existing code ..
let
> me know...
> Naseer
> Naseer MCA
> Using Tomcat but need to do more? Need to support web services,
security?
> Get stuff done quickly with pre-integrated technology to make
your job easier.
> Download IBM WebSphere Application Server v.1.0.1 based on
Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
<http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642>
> Geoserver-users mailing list
> Geoserver-users@lists.sourceforge.net
<mailto:Geoserver-users@lists.sourceforge.net>
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
Naseer MCA
