Hi Nunzio,
I’m not sure the issue is with your firewall. You can clearly get to the GeoServer admin console and the OpenLayers preview. I believe all WMS/WFS/WCS requests use the same port/url as the admin console page, so if one works, the other should too.
So the problem is probably with your layer/data being wrong instead.
Jonathan
On 17 January 2013 15:19, Nunzio Testa <nunzio.testa@anonymised.com> wrote:
Dear all,
i’m configuring OPEN GEO Suite and at the moment I have a problem configuration.
After the launch of Geo Server when I request a layer preview of “Medford” with Open Layer I don’t see anything.
Consider Geo Server is under a firewall.
Anyone knows which is the TCP port using by WMS service in order to configure the firewall.
I’m available for any clarification
Thank’s in advance
Nunzio Tesya
Master Visual Studio, SharePoint, SQL, ASP.NET, C# 2012, HTML5, CSS,
MVC, Windows 8 Apps, JavaScript and much more. Keep your skills current
with LearnDevNow - 3,200 step-by-step video tutorials by Microsoft
MVPs and experts. ON SALE this month only – learn more at:
[http://p.sf.net/sfu/learnmore_122712](http://p.sf.net/sfu/learnmore
_122712)
Geoserver-users mailing list
Geoserver-users@anonymised.comnet
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
