[Geoserver-users] GeoServer WMS post request with custom body?
Hello, I have an problem with GeoServer and Openlayers. I'm making a POST
request to GeoServer to query WMS layer (Openlayers WMS). The problem is
that Openlayers is creating a iFrame-element with transparent background and
it's not working with IE.
Is there a way to configure 'getMap' response body? I'd need to insert a
style definition to the body-element "background: transparent" so I could
make the iFrame working with IE.
(http://stackoverflow.com/questions/5133998/iframe-background-transparent-in-ie)
Thanks alot!
View this message in context: http://osgeo-org.1560.x6.nabble.com/GeoServer-WMS-post-request-with-custom-body-tp5092103.html
You’d probably be better served asking this on the OpenLayers list as it sounds like a JavaScript issue.
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
On 2 December 2013 08:18, sasuko <happogiri@anonymised.com> wrote:
Hello, I have an problem with GeoServer and Openlayers. I’m making a POST
it’s not working with IE.
Is there a way to configure ‘getMap’ response body? I’d need to insert a
style definition to the body-element “background: transparent” so I could
Thanks alot!
Rapidly troubleshoot problems before they affect your business. Most IT
organizations don’t have a clear picture of how application performance
affects their revenue. With AppDynamics, you get 100% visibility into your
Java,.NET, & PHP application. Start your 15-day FREE TRIAL of AppDynamics Pro!
http://pubads.g.doubleclick.net/gampad/clk?id=84349351&iu=/4140/ostg.clktrk
Geoserver-users mailing list
It’s quite strange. Which version of OpenLayers are you using? I suspect an old one.
Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via Poggio alle Viti 1187
mob: +39 331 6233686
On Mon, Dec 2, 2013 at 7:20 PM, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
Jonathan
Thanks alot!
