Is this layer grouping option in the SLD file? The WMS path grouping option? Or the 'Base map layer'
I haven't played with the WCS side of GeoServer much yet so I'm not quite sure if it is an issue or intentional.
If it is the MWS path option that you are using I think that it just groups the layers for the capabilities request. If you are using the base map layer option I think then it might be a bug.
So currently, if you use MapPane1 it works, but it doesn't work for MapPane2? I haven't used MapPane2 so I can't dig into what the issue there is.
Brent Owens
(The Open Planning Project)
Sándor Farkas wrote:
Hi Brent,
I'm using GeoServer 1.4.0-M2-WCS Beta. (as you know).
There is a layer grouping option in geoserver which I use for grouping my raster mosaic layers.
I found that pure WMS getmap request doesn't know this.
When I put this grouped layer in the layer list, only this layer is rendered.In Mapbuilder 1.0 with MapPane It worked well. I've tried it with MapPane2 too but it fails like in WMS getmap request.
How should I call this in wms query and in mapbuilder MapPane2?
Is this a bug or is it intentionally or do I something wrong?
I saw you read the Mapbuilder mailing list too. If you are competent please take a look at my question there too (subject Geobliki demo).
Sándor
