Hi. I’ve had to do a server reboot, tomcat7 is running, but I can’t get geoserver to restart.
Any help/suggestions hugely appreciated!
From the log:
2015-03-07 07:23:54,849 WARN [config.CustomEditorConfigurer] - Passing PropertyEditor instances into CustomEditorConfigurer is deprecated: use PropertyEditorRegistrars or PropertyEditor class names instead. Offending key [org.geotools.u$
2015-03-07 07:23:55,069 INFO [geoserver.global] -
- GEOSERVER_DATA_DIR: /var/lib/tomcat7/webapps/geoserver/data
2015-03-07 07:23:55,179 INFO [org.geoserver] - Loaded style ‘poly_landmarks’
2015-03-07 07:23:55,180 INFO [org.geoserver] - Loaded style ‘point’
2015-03-07 07:23:55,181 INFO [org.geoserver] - Loaded style ‘tiger_roads’
2015-03-07 07:23:55,181 INFO [org.geoserver] - Loaded style ‘line’
2015-03-07 07:23:55,182 INFO [org.geoserver] - Loaded style ‘cite_lakes’
2015-03-07 07:23:55,182 INFO [org.geoserver] - Loaded style ‘giant_polygon’
2015-03-07 07:23:55,183 INFO [org.geoserver] - Loaded style ‘simple_roads’
2015-03-07 07:23:55,183 INFO [org.geoserver] - Loaded style ‘burg’
2015-03-07 07:23:55,184 INFO [org.geoserver] - Loaded style ‘grass’
2015-03-07 07:23:55,184 INFO [org.geoserver] - Loaded style ‘polygon’
2015-03-07 07:23:55,185 INFO [org.geoserver] - Loaded style ‘capitals’
2015-03-07 07:23:55,185 INFO [org.geoserver] - Loaded style ‘pophatch’
2015-03-07 07:23:55,186 INFO [org.geoserver] - Loaded style ‘dem’
2015-03-07 07:23:55,186 INFO [org.geoserver] - Loaded style ‘rain’
2015-03-07 07:23:55,187 INFO [org.geoserver] - Loaded style ‘green’
2015-03-07 07:23:55,188 INFO [org.geoserver] - Loaded style ‘simple_streams’
2015-03-07 07:23:55,189 INFO [org.geoserver] - Loaded style ‘restricted’
2015-03-07 07:23:55,189 INFO [org.geoserver] - Loaded style ‘poi’
2015-03-07 07:23:55,190 INFO [org.geoserver] - Loaded style ‘raster’
2015-03-07 07:23:55,190 INFO [org.geoserver] - Loaded style ‘population’
2015-03-07 07:23:55,191 INFO [org.geoserver] - Loaded default workspace osgb
2015-03-07 07:23:55,194 INFO [org.geoserver] - Loaded workspace ‘sde’
2015-03-07 07:23:55,196 INFO [org.geoserver] - Loaded workspace ‘osgb’
2015-03-07 07:23:55,197 INFO [org.geoserver] - Loaded workspace ‘it.geosolutions’
2015-03-07 07:23:55,198 INFO [org.geoserver] - Loaded workspace ‘tiger’
2015-03-07 07:23:55,199 INFO [org.geoserver] - Loaded workspace ‘nurc’
2015-03-07 07:23:55,200 INFO [org.geoserver] - Loaded workspace ‘topp’
2015-03-07 07:23:55,201 INFO [org.geoserver] - Loaded workspace ‘sf’
2015-03-07 07:23:55,202 INFO [org.geoserver] - Loaded workspace ‘cite’
2015-03-07 07:23:55,321 INFO [org.geoserver] - Loaded store ‘250kResampled’, enabled
2015-03-07 07:23:55,324 INFO [org.geoserver] - Loaded coverage store ‘250kResampled’
2015-03-07 07:23:55,772 WARN [referencing.factory] - Axis elements found in a wkt definition, the force longitude first axis order hint might not be respected:
PROJCS[“WGS84 / Simple Mercator”, GEOGCS[“WGS 84”, DATUM[“WGS_1984”, SPHEROID[“WGS_1984”, 6378137.0, 298.257223563]], PRIMEM[“Greenwich”, 0.0], UNIT[“degree”, 0.017453292519943295]], PROJECTION[“Mercator_1SP_Google”], PARAMETER["latitud$
2015-03-07 07:23:56,036 INFO [org.geoserver] - Loaded coverage ‘250kResampled’, enabled
2015-03-07 07:23:56,042 INFO [org.geoserver] - Loaded coverage ‘250kResampled’
2015-03-07 07:23:56,488 WARN [imagemosaic.Utils] - Unable to find sample image for path /home/walkhigh/OSGBWebMapTools/Data/Tiles/250kResampled/sample_image
2015-03-07 07:23:56,488 WARN [gce.imagemosaic] - Unable to find sample image for path file:/home/walkhigh/OSGBWebMapTools/Data/Tiles/250kResampled/250kResampled.shp
2015-03-07 07:23:56,520 INFO [org.geoserver] - Loaded layer ‘250kResampled’
2015-03-07 07:23:56,524 INFO [org.geoserver] - Loaded store ‘MiniScale’, enabled
2015-03-07 07:23:56,524 INFO [org.geoserver] - Loaded coverage store ‘MiniScale’
2015-03-07 07:23:56,534 INFO [org.geoserver] - Loaded coverage ‘MiniScale’, enabled
2015-03-07 07:23:56,535 INFO [org.geoserver] - Loaded coverage ‘MiniScale’
2015-03-07 07:23:56,540 WARN [imagemosaic.Utils] - Unable to find sample image for path /home/walkhigh/OSGBWebMapTools/Data/Tiles/MiniScale/sample_image
2015-03-07 07:23:56,540 WARN [gce.imagemosaic] - Unable to find sample image for path file:/home/walkhigh/OSGBWebMapTools/Data/Tiles/MiniScale/MiniScale.shp
2015-03-07 07:23:56,541 INFO [org.geoserver] - Loaded layer ‘MiniScale’
2015-03-07 07:23:56,544 INFO [org.geoserver] - Loaded store ‘50kResampled’, enabled
2015-03-07 07:23:56,545 INFO [org.geoserver] - Loaded coverage store ‘50kResampled’
2015-03-07 07:23:56,552 INFO [org.geoserver] - Loaded coverage ‘50kResampled’, enabled
2015-03-07 07:23:56,553 INFO [org.geoserver] - Loaded coverage ‘50kResampled’
2015-03-07 07:23:56,568 WARN [imagemosaic.Utils] - Unable to find sample image for path /home/walkhigh/OSGBWebMapTools/Data/Tiles/50k2/sample_image
2015-03-07 07:23:56,568 WARN [gce.imagemosaic] - Unable to find sample image for path file:/home/walkhigh/OSGBWebMapTools/Data/Tiles/50k2/50kResampled.shp
2015-03-07 07:23:56,569 INFO [org.geoserver] - Loaded layer ‘50kResampled’
2015-03-07 07:23:56,573 INFO [org.geoserver] - Loaded store ‘250k’, enabled
2015-03-07 07:23:56,574 INFO [org.geoserver] - Loaded coverage store ‘250k’
2015-03-07 07:23:56,580 INFO [org.geoserver] - Loaded coverage ‘250k’, enabled
2015-03-07 07:23:56,581 INFO [org.geoserver] - Loaded coverage ‘250k’
2015-03-07 07:23:56,585 WARN [imagemosaic.Utils] - Unable to find sample image for path /home/walkhigh/OSGBWebMapTools/Data/Tiles/250k/sample_image
2015-03-07 07:23:56,585 WARN [gce.imagemosaic] - Unable to find sample image for path file:/home/walkhigh/OSGBWebMapTools/Data/Tiles/250k/250k.shp
2015-03-07 07:23:56,586 INFO [org.geoserver] - Loaded layer ‘250k’
2015-03-07 07:23:56,596 INFO [org.geoserver] - Loaded store ‘Overview1’, enabled
2015-03-07 07:23:56,596 INFO [org.geoserver] - Loaded coverage store ‘Overview1’
2015-03-07 07:23:56,604 INFO [org.geoserver] - Loaded coverage ‘Overview1’, enabled
2015-03-07 07:23:56,608 WARN [imagemosaic.Utils] - Unable to find sample image for path /home/walkhigh/OSGBWebMapTools/Data/Tiles/Overview1/sample_image
2015-03-07 07:23:56,608 WARN [gce.imagemosaic] - Unable to find sample image for path file:/home/walkhigh/OSGBWebMapTools/Data/Tiles/Overview1/Overview1.shp
2015-03-07 07:23:56,609 INFO [org.geoserver] - Loaded layer ‘Overview1’
2015-03-07 07:23:56,612 INFO [org.geoserver] - Loaded store ‘Overview2’, enabled
2015-03-07 07:23:56,613 INFO [org.geoserver] - Loaded coverage store ‘Overview2’
2015-03-07 07:23:56,620 INFO [org.geoserver] - Loaded coverage ‘Overview2’, enabled
2015-03-07 07:23:56,624 WARN [imagemosaic.Utils] - Unable to find sample image for path /home/walkhigh/OSGBWebMapTools/Data/Tiles/Overview2/sample_image
2015-03-07 07:23:56,624 WARN [gce.imagemosaic] - Unable to find sample image for path file:/home/walkhigh/OSGBWebMapTools/Data/Tiles/Overview2/Overview2.shp
2015-03-07 07:23:56,625 INFO [org.geoserver] - Loaded layer ‘Overview2’
2015-03-07 07:23:56,629 INFO [org.geoserver] - Loaded store ‘25k’, enabled
2015-03-07 07:23:56,629 INFO [org.geoserver] - Loaded coverage store ‘25k’
2015-03-07 07:23:56,634 INFO [org.geoserver] - Loaded coverage ‘25k’, enabled
2015-03-07 07:23:56,635 INFO [org.geoserver] - Loaded coverage ‘25k’
2015-03-07 07:23:56,678 WARN [imagemosaic.Utils] - Unable to find sample image for path /home/walkhigh/OSGBWebMapTools/Data/Tiles/25k/sample_image
2015-03-07 07:23:56,678 WARN [gce.imagemosaic] - Unable to find sample image for path file:/home/walkhigh/OSGBWebMapTools/Data/Tiles/25k/25k.shp
2015-03-07 07:23:56,679 INFO [org.geoserver] - Loaded layer ‘25k’
2015-03-07 07:23:56,683 INFO [org.geoserver] - Loaded store ‘50k’, enabled
2015-03-07 07:23:56,684 INFO [org.geoserver] - Loaded coverage store ‘50k’
2015-03-07 07:23:56,689 INFO [org.geoserver] - Loaded coverage ‘50k’, enabled
2015-03-07 07:23:56,690 INFO [org.geoserver] - Loaded coverage ‘50k’
2015-03-07 07:23:56,703 WARN [imagemosaic.Utils] - Unable to find sample image for path /home/walkhigh/OSGBWebMapTools/Data/Tiles/50k4/sample_image
2015-03-07 07:23:56,703 WARN [gce.imagemosaic] - Unable to find sample image for path file:/home/walkhigh/OSGBWebMapTools/Data/Tiles/50k4/50k.shp
2015-03-07 07:23:56,704 INFO [org.geoserver] - Loaded layer ‘50k’
2015-03-07 07:23:56,765 INFO [storage.DefaultStorageFinder] - *****************************************************************************************************************************
2015-03-07 07:23:56,765 INFO [storage.DefaultStorageFinder] - *** Found Servlet context parameter GEOWEBCACHE_CACHE_DIR set to /var/lib/geoserver_data, using it as the default prefix. ***
2015-03-07 07:23:56,765 INFO [config.XMLConfiguration] - Will look for geowebcache.xml in ‘/var/lib/geoserver_data’
2015-03-07 07:23:56,878 INFO [gwc.layer] - Initializing GWC configuration based on GeoServer’s Catalog
2015-03-07 07:23:56,878 INFO [gwc.layer] - GeoServer TileLayer store base directory is: /var/lib/tomcat7/webapps/geoserver/data/gwc-layers
2015-03-07 07:23:56,878 INFO [gwc.layer] - Loading tile layers from /var/lib/tomcat7/webapps/geoserver/data/gwc-layers
2015-03-07 07:23:56,932 INFO [gwc.layer] - GWC configuration based on GeoServer’s Catalog loaded successfuly
2015-03-07 07:23:56,932 INFO [config.XMLConfiguration] - Found configuration file in /var/lib/geoserver_data
2015-03-07 07:23:56,951 INFO [config.XMLConfiguration] - Configuration file validated fine.
2015-03-07 07:23:56,960 INFO [config.XMLConfiguration] - Initializing GridSets from /var/lib/geoserver_data
2015-03-07 07:23:56,960 INFO [config.XMLConfiguration] - Read GridSet OSGB
2015-03-07 07:23:56,960 INFO [config.XMLConfiguration] - Initializing layers from /var/lib/geoserver_data
2015-03-07 07:23:56,961 INFO [layer.TileLayerDispatcher] - Configuration /var/lib/geoserver_data contained no layers.
2015-03-07 07:23:56,974 INFO [storage.MetastoreRemover] - Cleaning up the old disk quota database
2015-03-07 07:23:56,983 INFO [diskquota.ConfigLoader] - Quota config is: /var/lib/geoserver_data/geowebcache-diskquota.xml
2015-03-07 07:23:57,441 INFO [diskquota.ConfigLoader] - Quota config is: /var/lib/geoserver_data/geowebcache-diskquota.xml
2015-03-07 07:23:57,445 INFO [diskquota.DiskQuotaMonitor] - Setting up disk quota periodic enforcement task
2015-03-07 07:23:57,445 INFO [diskquota.DiskQuotaMonitor] - 0 layers configured with their own quotas.
2015-03-07 07:23:57,446 INFO [diskquota.DiskQuotaMonitor] - 8 layers attached to global quota 40.0 GB
2015-03-07 07:23:57,455 INFO [diskquota.DiskQuotaMonitor] - Disk quota periodic enforcement task set up every 5 SECONDS
2015-03-07 07:23:57,512 INFO [org.geoserver] - Loaded service ‘wcs’, disabled
2015-03-07 07:23:57,529 INFO [org.geoserver] - Loaded service ‘wfs’, disabled
2015-03-07 07:23:57,546 INFO [org.geoserver] - Loaded service ‘wms’, enabled
2015-03-07 07:23:57,552 INFO [gwc.config] - Initializing GeoServer specific GWC configuration from gwc-gs.xml
2015-03-07 07:23:57,605 INFO [ows.OWSHandlerMapping] - Mapped URL path [/gwc/service/] onto handler ‘dispatcher’
2015-03-07 07:23:57,622 INFO [geowebcache.GeoWebCacheDispatcher] - Invoked setServletPrefix(gwc)
2015-03-07 07:23:57,630 INFO [georss.GeoRSSPoller] - Initializing GeoRSS poller in a background job…
2015-03-07 07:23:57,632 INFO [georss.GeoRSSPoller] - No enabled GeoRSS feeds found, poller will not run.
2015-03-07 07:23:57,682 INFO [rest.RESTDispatcher] - Created RESTDispatcher with 13 paths
2015-03-07 07:23:57,702 INFO [wms.WMSService] - Will NOT recombine tiles for non-tiling clients.
2015-03-07 07:23:57,702 INFO [wms.WMSService] - Will proxy requests to backend that are not getmap or getcapabilities.
2015-03-07 07:23:58,540 INFO [ows.OWSHandlerMapping] - Mapped URL path [/kml] onto handler ‘dispatcher’
2015-03-07 07:23:58,540 INFO [ows.OWSHandlerMapping] - Mapped URL path [/kml/*] onto handler ‘dispatcher’
2015-03-07 07:23:58,540 INFO [ows.OWSHandlerMapping] - Mapped URL path [/kml/icon//] onto handler ‘kmlIconService’
2015-03-07 07:23:58,613 INFO [ows.OWSHandlerMapping] - Mapped URL path [/ows/] onto handler ‘dispatcher’
2015-03-07 07:23:58,613 INFO [ows.OWSHandlerMapping] - Mapped URL path [/ows] onto handler ‘dispatcher’
2015-03-07 07:23:58,622 INFO [org.geoserver] - GeoServer configuration lock is enabled
2015-03-07 07:23:58,689 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wcs] onto handler ‘dispatcher’
2015-03-07 07:23:58,689 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wcs/] onto handler ‘dispatcher’
2015-03-07 07:23:59,266 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wfs/] onto handler ‘dispatcher’
2015-03-07 07:23:59,266 INFO [ows.OWSHandlerMapping] - Mapped URL path [/TestWfsPost] onto handler ‘wfsTestServlet’
2015-03-07 07:23:59,266 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wfs] onto handler ‘dispatcher’
2015-03-07 07:24:01,818 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wms/] onto handler ‘dispatcher’
2015-03-07 07:24:01,818 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wms] onto handler ‘dispatcher’
2015-03-07 07:24:01,883 INFO [ows.OWSHandlerMapping] - Mapped URL path [/animate] onto handler ‘dispatcher’
2015-03-07 07:24:01,883 INFO [ows.OWSHandlerMapping] - Mapped URL path [/animate/] onto handler ‘dispatcher’
2015-03-07 07:24:01,973 INFO [georss.GeoRSSPoller] - destroy() invoked
2015-03-07 07:24:01,973 INFO [geowebcache.GeoWebCacheDispatcher] - GeoWebCacheDispatcher.destroy() was invoked, shutting down.
2015-03-07 07:24:01,975 INFO [diskquota.DiskQuotaMonitor] - Disk quota monitor shutting down…
2015-03-07 07:24:01,975 INFO [diskquota.DiskQuotaMonitor] - Shutting down quota usage monitor…
2015-03-07 07:24:01,976 INFO [diskquota.QuotaUpdatesMonitor] - Shutting down quota usage monitor…
2015-03-07 07:24:01,976 INFO [diskquota.DiskQuotaMonitor] - Shutting down quota statistics gathering monitor…
2015-03-07 07:24:01,976 INFO [diskquota.QueuedQuotaUpdatesConsumer] - Shutting down quota update background task due to InterruptedException
2015-03-07 07:24:01,976 INFO [diskquota.QueuedUsageStatsConsumer] - Shutting down quota update background task due to interrupted exception
2015-03-07 07:24:01,977 INFO [jdbc.JDBCQuotaStore] - Closing up the JDBC quota store
2015-03-07 07:24:02,015 INFO [seed.SeederThreadPoolExecutor] - Initiating shut down for running and pending seed tasks…
2015-03-07 07:24:02,016 INFO [seed.SeederThreadPoolExecutor] - Seeder thread pool executor shut down complete.
2015-03-07 07:24:02,016 INFO [storage.DefaultStorageBroker] - Destroying StorageBroker
2015-03-07 07:24:02,017 WARN [support.DisposableBeanAdapter] - Invocation of destroy method failed on bean with name ‘geoServerLoader’: org.springframework.beans.factory.BeanCreationNotAllowedException: Error creating bean with name 'GW$
