[Geoserver-users] GeoServer WPS InclusionFeatureCollection problem
Hi everyone, I'm having trouble with the WPS gs:InclusionFeatureCollection process when using a layer as the first input and a geojson feature collection as the second input:
Request: https://gist.github.com/mbertrand/ac76e0994f8623d687dc#file-broken_inclusion_by_layer_vectorbuffer-xml
Response:
  "type": "FeatureCollection",
  "features":
Zero features are returned, but that is incorrect.
When using two vector layers as inputs (via a chained response, buffering one feature from a vector layer), the correct features are returned:
Request: https://gist.github.com/mbertrand/ac76e0994f8623d687dc#file-working_inclusion_by_vectorlayer-xml
Response: https://gist.githubusercontent.com/mbertrand/ac76e0994f8623d687dc/raw/50c53ccadcc5aa6117e4a85ec5ba196f5fbed4f5/working_inclusion_by_vectorlayer_result.json
However, I need to create buffers around user-defined lines rather than existing layer features, which rules out the working option. I'm wondering if there's something off with my request XML in the first example above or if this is a Geoserver bug? I've also tried "vec:InclusionFeatureCollection" with the same results. I'm using Geoserver 2.7.4
Matt
it makes me wonder if there is a problem with the geojson parsing… did you try with gml instead?
On Thu, Jan 21, 2016 at 2:01 PM, Matt Bertrand <matt@anonymised.com> wrote:
Hi everyone, I’m having trouble with the WPS gs:InclusionFeatureCollection process when using a layer as the first input and a geojson feature collection as the second input:
Response:
“type”: “FeatureCollection”,
“features”:
However, I need to create buffers around user-defined lines rather than existing layer features, which rules out the working option. I’m wondering if there’s something off with my request XML in the first example above or if this is a Geoserver bug? I’ve also tried “vec:InclusionFeatureCollection” with the same results. I’m using Geoserver 2.7.4
Matt
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=267308311&iu=/4140
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks Andrea,
I switched to to GML and got it working: https://gist.github.com/mbertrand/ac76e0994f8623d687dc#file-inclusion_gml_3857_working-xml
Oddly if both inputs are GeoJSON then it works: https://gist.github.com/mbertrand/ac76e0994f8623d687dc#file-inclusion_two_json_working-xml
-Matt
Response:
“features”:
Matt
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Matt,
glad it works for you… bummer about the geojson support, not sure what went wrong there.
Would you have time to open a bug report here?
https://osgeo-org.atlassian.net/projects/GEOS/summary
On Fri, Jan 22, 2016 at 5:47 AM, Matt Bertrand <matt@anonymised.com> wrote:
Thanks Andrea,
-Matt
On Jan 21, 2016, at 5:49 PM, Andrea Aime <andrea.aime@anonymised.com1107…> wrote:
Response:
“features”:
Matt
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Sure, here is the issue I opened: https://osgeo-org.atlassian.net/browse/GEOS-7386
-Matt
Thanks Andrea,
-Matt
On Jan 21, 2016, at 5:49 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Response:
“features”:
Matt
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
